S500 W221 2006 Is it repeable
Old Apr 17, 2026 | 01:58 PM
kAzilAs's Avatar
Hello
I have a 2006 Mercedes S500 (W221). This part is located in the trunk and is responsible for the automatic trunk closing.
Does anyone know if this part is repairable? Has anyone had a similar issue before? Do you think it’s possible to weld or fix the broken bracket, or does the whole unit need to be replaced?
Thanks in advance!
Second question: Is the part itself (the piston) is intact and not broken, nothing is missing from it, right? Like a circlip, for example?
Old Apr 17, 2026 | 02:18 PM
Jaap's Avatar
2006 W221 S500L M273
Yeah that's going to need welding and reinforcemennt, maybe with an extra plate if room permits.
I'd say take it to a body shop
Old Apr 17, 2026 | 02:52 PM
Senecat's Avatar
1983 Nissan Shltbox
Anything is repairable bro. eBay if your resources for said repair are lacking.
Old Apr 17, 2026 | 02:57 PM
kAzilAs's Avatar
Thank you for your response! In your opinion, the part itself (the piston) is intact and not broken, right? Only the bracket needs to be welded.
Old Apr 17, 2026 | 03:29 PM
Max Blast's Avatar
NGL450 w/EORP, S550
All repairs range from anything from JB Weld to actual hot work.
What you can do is metal bond two washers to either side of this cracked flange after you force the crack shut. Then screw the ram back on and it should hold.
this is what JB weld/araldite is for
Old Apr 17, 2026 | 03:46 PM
Senecat's Avatar
1983 Nissan Shltbox
Probably not worth the time or effort when a new bracket can be pulled from a yard or off eBay for probably next to nothing.
Old Apr 17, 2026 | 04:58 PM
AL5461's Avatar
W221 S500
Is there a repair piece or replacement bracket plate?
Be in rear end structure on the EPC.
Old Apr 18, 2026 | 04:25 AM
BOTUS's Avatar
S500
just have a normal better manual boot opening system - faster, reliable and you can better control the rain flooding in and shorting out your TV tuner, Amp and reversing module
Old Apr 18, 2026 | 04:49 AM
AL5461's Avatar
W221 S500
Actually you can't because it won't stop where you stop it but rather ping right open. It's the hydraulic ram that gives it the ability to hold position.
