S-Class (W222) 2014-2020
Quick way to turn off fan?
Old Jan 17, 2016 | 01:19 AM
hayden's Avatar
2015 S550, 2016 Escalade
Am I correct that there is no quick way to turn off the AC fan other than clicking on the "Menu" button in the middle of the AC controls, then down with your COMMAND controller, then pushing down to turn it off?
I was hoping there was a faster way without going thru COMMAND.
Old Jan 17, 2016 | 06:44 AM
wows500's Avatar
2015 S550 4matic, 1960 Chevy Impala Conv, (Previously 2002 S500, 2008 S550 4Matic)
That's how I have been doing. Pretty annoying.
Old Jan 17, 2016 | 09:00 AM
blevinson's Avatar
2014 S550, 2013 GL450
You can set one of the favorite buttons on the command keypad to "climate off"
Old Jan 17, 2016 | 09:19 PM
hayden's Avatar
I get an error that you cannot save that as a favorite.
I can't name another vehicle that cannot turn off the fan with a hard button quickly.
Old Jan 18, 2016 | 08:45 PM
Steinhart's Avatar
2018 S 650, 2014 SL 550, 2017 911 TTS Cab, '13 F458 Spider
In my '13 and '14 E350's the lowest fan setting actually turned the fan/ac off, I haven't tried it on the S yet...
Old Jan 18, 2016 | 08:59 PM
hyperion667's Avatar
2012 CLS63
I use this method too, very easy with the secondary button on the keypad if it's MY 14
Old Jan 19, 2016 | 12:21 PM
Diesel Benz's Avatar
Could you explain your scenarios for turning the AC fan off? I would have assumed turning recirculation on would be sufficient instead of turning the fan off?
Pretty quick to turn fan speed down too from the specific button (would need to have "sync on" to turn both sides simultaneously, not sure if rear would need another approach).
Old May 15, 2016 | 12:20 PM
lightninhopkins's Avatar
2015 S550
I was surprised to see a thread on this, with this few people. It's definitely the most ridiculous (non)-feature I've seen in decades of car ownership.
I have to navigate through 4 steps to turn off the climate control? What a joke.
Old May 15, 2016 | 02:29 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
Just hit the down button a number of times.
Old May 16, 2016 | 12:26 AM
2015 S550
I just discovered the favorites menu as you guys have mentioned (never really knew about it). I put the climate on/off first, so it's 2 buttons instead of 3 or 4 now. Thanks.
Old May 16, 2016 | 12:39 AM
Steinhart's Avatar
what is the favorites menu and how do I program it?
Old May 16, 2016 | 12:58 AM
2015 S550
If you press the star button ★ (3rd of 3) on the center console command trackpad thing, you can see the pre-programmed favorites. If you slide down a section, you can move the items to the left and right. The climate control is in there somewhere. I moved mine to the first position and driver seat massage to the 2nd location. Cool menu for quick actions.
Old May 16, 2016 | 07:54 AM
2012 CLS63
have you tried to RTFM?
