Drivers side active multi contour seat not working in my 2015 S550
same as you, everything else works. I have to swing by the dealer tomorrow and will ask them to look at it.
I'd try to play with the controls some more.......versus banging your head up against the wall at a dealership.
Good luck.
I had to replace a frame on a front passenger seat in a 65 with limo package, the power footrest and all. It was horrible to get all the covers fit back properly and working as designed. Many mechanics aren't as through as they should be.
I remember it was a pretty cool feature. Especially when physics does it's thing with heavy people.
The PSE pump that drives all the air functions operates on about 1 bar of pressure, not too much really, but the bladders are large so it makes a big difference.
If the pump isn't working, nothing will work at all.
If the responses seem delayed or soft, most likely it's the controller, which is located in each seat and is responsible for directing the air in and out of the desired bladders.
Next time drink all the coffee and eat all the doughnuts.........
