S-Class (W222) 2014-2020
Doors don't always unlock
Old Jul 13, 2018 | 11:31 AM
alexpush's Avatar
s550
When the key is in my pocket and I touch the door handle, it unlocks, but not 100% of the time. Sometimes it doesn't unlock. My other car is a Chrysler and it unlocks every single time. Does anyone else have this problem? Any tips or tricks I should know? Thanks guys...
Old Jul 13, 2018 | 02:37 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
Mine was doing that a lot recently. Turns out my key fob battery was low. Got the fob battery replaced 2 days ago. So far things are doing fine.
Old Jul 13, 2018 | 06:05 PM
Merserybenze's Avatar
2022 AMG GT 53, 2020 Sl450. Did drive 2018 S450
had the same issue.I discovered sometimes I would double click the key fob to lock the doors. When i did this i could not open the doors by touch next time. took me a while to figure out the pattern.
Old Jul 13, 2018 | 08:33 PM
S550e's Avatar
W222 S550e, C207 E550, W212 E350
I had that problem too. After changing the key fob batteries it worked. Interesting what Merserybenze said, I always double click.
Old Jul 13, 2018 | 08:44 PM
mikey94025's Avatar
2015 S550 Coupe
News to me too -- A little web searching and here is the feature for temporarily disabling keyless-go for a particular fob: http://www.benzblogger.com/2015/01/m...n-and-off.html
Still a good idea to change your battery, but be careful too that you're not disabling KG on your fob.
Old Jul 15, 2018 | 07:14 PM
stever500's Avatar
2025 S63. 2022 911 Turbo S, 23 BMW M5C
Mine doesn't open the door a lot, and it's brand new (4 months old so the battery should be fine). I'm not happy about this and will eventually ask the dealer about it next time I'm there. I've found that sometimes when I stand more directly in the center of the door it will work but when not standing that way, it won't.
Old Jul 15, 2018 | 11:13 PM
S63AMG888's Avatar
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
I would try replacing the key fob battery ( less than $3.00 ) before visiting the dealer ( gas alone is more than $3.00 ) unless you double click the door handle that disable the keyless go. No matter how new the car is, please keep in mind the key fob and battery is made several months even years before you even get the car.
Old Jul 16, 2018 | 07:59 AM
Delta5275's Avatar
2018 S63 Sedan, 2018 GLS 63
Mine was built in March. Since day 1 it works when it wants to.
Old Jul 16, 2018 | 09:13 AM
alexpush's Avatar
s550
It looks like you're correct. It works perfectly when I single click. And doesn't unlock when I double click
Old Jul 16, 2018 | 09:25 AM
2012 merc amg's Avatar
2018 S560
Ya these FOB batteries do not last long. I'd rather just have the old setup with a regular key, less worry then too of having your car hacked into and stolen. That is becoming a real problem in some areas of the country.
Old Jul 16, 2018 | 07:18 PM
MBS63AMG's Avatar
You are EXACTLY right about that.
Old Jul 17, 2018 | 01:29 AM
mikey94025's Avatar
2015 S550 Coupe
If you're really worried about keyless go then you can turn it off and just use the physical key to turn on the ignition.
