S-Class (W222) 2014-2020
Cornering Lights on 2018/2019 S Class Models
Old Aug 19, 2019 | 01:25 PM
DonS550's Avatar
2021 S580 4MATIC with Rear Executive Seating Pkg. 4D Entertartainment Rear Screens Pkg.
I can't get a definitive answer. Are the Cornering Lights on Multibeam S Class headlights inoperable for US models (particularly the S450)?
Old Aug 19, 2019 | 02:12 PM
SteveVukelich's Avatar
2020 S560
No, I am in the US and they work fine on mine. They are built into the headlamp and are speed, ambient lighting, and steering wheel position sensitive.
Old Aug 19, 2019 | 03:14 PM
DonS550's Avatar
I have been told mixed messages. one dealer says they should work. The other says they're not on the S450 but on the S560, I had MBUSA customer care say they are not active per US standards (one caller); I have another stating they should work.
Mine do not work although they are present in the vehicle. If you have a 2018 S class, please show me photos that yours are working by sending a photo.
Thanks,
Old Aug 19, 2019 | 03:33 PM
2020 S560
Go to page 148 of the S class owner's manual. It describes the function with a cartoon of how it works. I cannot take a picture since it will not operate unless the car is moving.
Old Aug 19, 2019 | 03:34 PM
2020 S560
I know it works because I just drove in the dark last night and they worked as advertised. I have a S560.
Old Aug 19, 2019 | 03:51 PM
salamigs's Avatar
2018 S560; 2021 GLS450
Confirming that it works on 2018 S560. I believe, although I have not tried, only when the light switch is set to Auto though.
Old Aug 20, 2019 | 11:06 AM
MikeAtLincoln's Avatar
Veteran: Army
2018 S450
Mine work fine, I have a 2018 S450.
Old Sep 2, 2019 | 04:51 PM
DonS550's Avatar
Cornering Light S450.
Can you send me a video clip or something that shows the cornering light illuminating upon turning on your signal lamp? Mine are not operating at all and have been told S450s don’t have them.
Old Sep 3, 2019 | 10:45 AM
Veteran: Army
2018 S450
I don't believe the cornering function is tied to the turn signal. When I turn the steering wheel the headlights follow. I leave my light control switch in auto.
Old Sep 4, 2019 | 05:46 PM
DonS550's Avatar
Actually the cornering light function IS tied to the turn signal. I have a friend who owns an S560 and I placed a black paper over the light sensor in the windshield (between the two stereo cameras) his lights automatically came on. I asked him to turn on each signal light and wollah! his cornering lights lit up on the respective sides. I just tested this out before writing this post. Also, the cornering light function illuminated on both sides simultaneously, when he put the car in reverse. The function can be tested by covering the light sensor with a dark piece of paper (or your car manual leather binder). Test it, turn on your signal and tell me if the cornering lights illuminate on your S450? If they do, then something is going on with mine.
Old Sep 6, 2019 | 09:08 AM
ajm0623's Avatar
'25 740i; '15 targa4s; '24 cayenne
i have an '18 s450; it is equipped with cornering lamps as standard. and they work as intended. whenever i move the wheel slightly - in either direction - at low speeds - that side of the car to which i moved the wheel illuminates. the lamps also illuminate when i use the turn indicators. i live in the usa. exteriour lamps set to auto. too hard/dangerous to capture the images with pictures or video whilst driving. op will need to take my word for it - my s450's cornering lamps work brilliantly (pun!).
Old Sep 6, 2019 | 03:13 PM
DonS550's Avatar
Ajm0623, YES! That’s exactly how they are supposed to work! And they work when standing at an intersection. Today, I went to my stealership and showed the service manager, who kept telling me all the lights are working, and asked him to grab the keys as I took him with me to one of the S450’s on the lot. We cranked the car up, turned the wheel left and right then used the signals (we had to cover the light sensor with a black towel). The cornering lights (which are tucked into the inside of the housing right behind the daytime running lights) lit up! The service guys ran a computer program in an attempt to reprogram the cornering lights; didn’t work. Now they had to write in to Germany for a program to have the cornering lights “follow the command” of what the car is asking them to do . . . . Light up at night, when standing at intersections or turning corners or backing up. To all in the thread who thought that this only occurs while the car is moving, I’m not sure you know exactly what cornering lights are. . . . Or if yours even work; these are very distinct lights, you’d know if you have them . . . You’d miss them if you no longer had them.
