S-Class (W222) 2014-2020
help please...error message: merecedes me connect
Old Nov 2, 2019 | 04:50 PM
Steinhart's Avatar
2018 S 650, 2014 SL 550, 2017 911 TTS Cab, '13 F458 Spider
I'm getting this message every time I start my car. It's been happening for several weeks. My service manager tells me it's an issue with mbrace, not my car. I do not subscribe to mbrace.
Does anyone else have this problem?
Old Nov 2, 2019 | 05:05 PM
pgsurface's Avatar
83 300D 617T(retired), 96 E300 606n/a(retired), 99 E300 606T(retired), 07 E320 BT, 14 E3504M
Do you park in a garage or very close to a building? or outdoors? If the GPS signal is blocked to the hermes module it will show an error code for this. Your dealer should have ran a short test for you.. there should be stored faults for this.
Old Nov 2, 2019 | 05:09 PM
Steinhart's Avatar
I get this message everywhere, whenever I start the car. I brought it the dealer yesterday, he looked at it and just told me it was not my car, but an issue they are apparently having with mbrace. But this has been happening for weeks...
Old Nov 2, 2019 | 07:33 PM
SteveVukelich's Avatar
2020 S560
Mercedes Me Connect is not mbrace. It is a completely different service. Yes, it was down for a short time on 11/25 and 11/26. If you are still having problems outside of this date window then the services were not properly activated. In your purchase paperwork there is a web site to go to to check that your service is properly initialized. Or press the Me button in you car and ask for help.
Old Nov 2, 2019 | 07:35 PM
Steinhart's Avatar
ahh, much appreciated Steve, I will do that, my service manager was clueless
Old Nov 2, 2019 | 08:17 PM
MichaelinATL's Avatar
S 550 AMG Sport Package
Unhappy Mercedes Me Application is Down
Application is offline because their IT department has issues and lacks world class availability
Old Nov 2, 2019 | 08:19 PM
Steinhart's Avatar
Old Nov 2, 2019 | 08:31 PM
2020 S560
Not here. System is running
normally.
Old Nov 3, 2019 | 08:53 AM
2020 S560
An additional thought. Did you go to https://myvehicle.att.com/#/login to create an account with AT&T to access your car? This step is not often mentioned during the initialization process.
Old Nov 3, 2019 | 09:06 AM
Steinhart's Avatar
didn't you say the '18 model year used Verizon?
I use At&T though
Old Nov 3, 2019 | 09:11 AM
2020 S560
I use At&T though
My 2018 S class used Verizon for in-car services. My 2020 S class uses AT&T for in-car services. Your personal phone is not used for web browsing, weather, GPS, etc.
Old Nov 3, 2019 | 09:20 AM
Steinhart's Avatar
I notice that calls placed inside my car are slower and more difficult to connect, compared to using my phone outside my car.
Is this because I am connecting through the car's slower 3G connection?
If so, then I should not pair my phone to that slower system...
Old Nov 3, 2019 | 09:35 AM
steve sl550's Avatar
1986 560SL, 2017 E300, 2018 Sl550, 2020 E350
Way it was explained to me:
2019 and newer uses Merceded "me" and no problem with the system and other than concierge is no cost for 3 yrs
Older than 2019 uses MBRACE (different provider to MB than the newer "me" and presently has issues), also is and always was a cost to subscribe after 6 mo free trial
I have a 2018 SL550 that uses MBRACE and has a different application icon than the application for my new 2020 E350 that uses "me" (so 2 apps one for MBRACE the other for "me"
Old Nov 3, 2019 | 09:44 AM
2020 S560
Your personal phone does not connect to the on-board Mercedes system, they are entirely separate. You may be getting poor service on your personal phone because of the sun-block coating on the windows. However, some personal phones can utilize the built-in external antenna (located above the rear window on the roof, looks like a shark fin). It can be used by plugging the phone into the right-side USB port in the center arm rest; this is the same port for Apple Carplay. Not all phones can access the external antenna though; if your phone can access the NFC system (see the stylized N inside the front center armrest) then it likely can access the external antenna.
Old Nov 3, 2019 | 09:51 AM
Steinhart's Avatar
good to know! thanks
Old Nov 3, 2019 | 09:52 AM
Steinhart's Avatar
thank you
Old Nov 4, 2019 | 05:47 PM
MTrauman's Avatar
'25 S63 AMG E Performance, '26 CLE 53 AMG
This is true in the US but in Europe a person’s personal phone is used for data connections. When I rented a 2017 S63 AMG in the summer of 2017 I used my US cell phone as a data connection.
Old Nov 5, 2019 | 12:17 PM
Steinhart's Avatar
so I may have finally found the cause of the error message....
MB is telling me it's due to the tracking device my insurance (State Auto) had me install in the OBD port to qualify for their premium discount
I guess I will leave it connected, at least for now
Old Nov 6, 2019 | 05:18 PM
aypues's Avatar
04 Lexus LS430
which carrier is on 2019 models?
Old Nov 6, 2019 | 07:58 PM
MTrauman's Avatar
AT&T—same as 2020 models.
Old Nov 11, 2019 | 03:55 PM
2020 S560
Try going here: https://www.me.mercedes-benz.com/pas...rcedes-me.html
This bypasses the error message if you want to download map updates to a USB stick from a PC/Mac web browser so that you can manually update.
Old Nov 11, 2019 | 04:17 PM
Steinhart's Avatar
will do, thanks
