S-Class (W222) 2014-2020
Intermittent seat massager Issue. Works about a half hour.
Old Mar 16, 2021 | 10:01 PM
2012 merc amg's Avatar
2018 S560
I have a fairly recent problem with the Seat Massager in my S560 that started about a month ago or so. I turn on either the drivers or passenger seat massager and it works for about first cycle or two and then after around a half hour will not come back on. It just flashes a split second on the screen where the dot is for the type of massage and will not stay highlighted. I can pull over and turn the car off and open the door and then it will work again for another 1/2 hour or so. I know the dealer will say cannot duplicate with this kind of intermittent problem and I'll never get it fixed so trying to see if anyone else has had a similar problem and what the problem ended up being. I would suspect that the seat massager module just needs a software reflash or something like that. Last time I brought the car to the dealer they said they could not even look at it as they did not have the time. Sometimes I think these things called warrantees are fairly useless and I should just get a good independent shop to service my cars and not bother with extended warranties anymore.
Old Mar 16, 2021 | 10:40 PM
Denis Osullivan's Avatar
2018 s560v4
I came across another post and read that it will not remain on. It must be reset by restarting the car. Im guessing its a safety feature.
Old Mar 16, 2021 | 10:44 PM
2018 S560
It never use to do this in any of the mercedes I have had. You could turn it back on as much as you wanted on a long trip. Whenever it timed out, you could hit on the same type of message or a different one, something is not normal that it only works for a half hour or so. That would be more dangerous if people had to pull over into the breakdown and turn their cars off and open the door a second to get another 1/2 of a back message, lol.
Old Mar 17, 2021 | 05:41 AM
kafklatsch's Avatar
All Cars Lost To Hurricane Isaac (W124 E420 revived - added 88 Allante 14 S550, 17 S63
I have experience with four sedans with the feature, two currently . In all the vehicles, when the massage reaches its end, pushing the massage button restarts the massage.
This rinse repeat cycle has no end as long as the car is running.
It does not require additional driver intervention such as a car restart.
Old Mar 17, 2021 | 12:00 PM
Jagbuxx's Avatar
2020 S450 plus 10 others & 2019 Tiffin Phaeton 40AH
My S450 massager will restart after the time out be clicking on the massage icon.
Old Mar 17, 2021 | 12:03 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
In our E550 with multi-contour seats the massage lasts for 30min, then you reactivate it and it runs for another 30 min, and so on.
Old Mar 17, 2021 | 10:52 PM
2018 S560
Thats how mine use to be but not anymore, I guess it's either the pump or a software or sensor related issue. I have the feeling I'll be told it is normal, thats how it generally goes. The car is at the dealer now, I picked up the loaner late today.
Old Mar 18, 2021 | 06:51 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
Are you willing to pay the gas, mileage, and tech time for him to drive it through a cycle and get a readout on the error ?
Old Mar 18, 2021 | 07:50 PM
2018 S560
Well the car is under warranty and I’d be paying for the gas there’s a half tank in the car now. There’s Gotta be a way to diagnose these things. Maybe the pump is pulling too much current I dunno. I paid big bucks for this car and big bucks for the Warrantee I want it to function as designed to function by Mercedes. I’m really tired of excuses and going to get a lot more aggressive on getting things covered under Warrantee that should be covered.
Old Mar 19, 2021 | 01:02 PM
Top Answer: 1
S600
I would bet it is the pump also, but the question is it the pump motor getting hot, or is it the pump impeller cavitating ?
Old Apr 5, 2023 | 11:30 AM
jpetrol251's Avatar
2000 CL ,2004 gallardo
mine is doing the exact same thing, i have to restart the car for lumbar to work again. what was the problem?
Old Apr 5, 2023 | 05:34 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Is it like the seat heater, only runs so long then shuts off? That's what my car has always done, assume it's to avoid draining the battery, etc.
Old Apr 5, 2023 | 05:57 PM
2018 S560
Just noticed this post being brought back up again and I didn't say what the solution was. I had the car at the dealer in RI must have been about a year and half ago or so and they find there to be a leaking plastic line in the drivers seat for one of the seat bladders. They had to custom make a new line as the one from mb germany was on backorder ever since my seat massagers have worked fine. When there is any type of leak in any of the lines or pump it trips a error code I believe in the BCM and then stops working properly, this is what happened. Good thing I got it in when I did as the factory warranty was just about to run out at the time and it's pretty doubtful a repair like this would have been covered under the extended warranty.
W205C43PFL's Avatar
I wonder if the massager just got tired.... 🤔
