S-Class (W222) 2014-2020
Just Purchased a S560
Old May 1, 2021 | 01:08 PM
ihbond's Avatar
w222 s560
Hi , My name Is Ian. I am out here in the PNW (tacoma area)..and we just purchased a slightly used 2020 s560 4matic SEDAN CPO from Mercedes Seattle..20" amp staggered wheels..
My last experience with Mercedes was a Komrpessor engine, and I swore I would never go back..But the interior of s560 drew us back in, and just didn't like the w223 interior.
I have gone through the threads (so I sincerely apologize as I know this has been asked a few times, I just am not connecting the dots on a few things I still need help on to assist me ..
  1. can someone help me with the model\part number for a Spare (to keep in the back while going on road trips) and the lugnuts\bolts I might need (size)..I got confused as. I noticed some folks using amg w221 (I think)..or point me to a thread I may have missed..
  2. has anyone had any experience with continental tire Non-Run flats vs the Bridgstone Non-Run Flats. 20"
    1. ........... I was thinking of this route, in case we do get a flat, and need a new tire within a day (most tire companies out here can get them pretty quick)
  3. Also...If we did end up buying new rims and going the 19" is the AMG wheel\RIM still as soft as the 20's or would after market be a better way to go ?
  4. Has anyone tried the following for CarPlay https://cplay2air.com/products/cplay...8aAuXmEALw_wcB
    Well thanks for any advice..
Old May 3, 2021 | 09:25 AM
AbbyKay's Avatar
2020 S560 4Matic
There are several tire/wheel threads in the forum - many opinions and suggestions. You'll want to do some surfing.
As for Carplay - the 2020's come with Carplay. One fo the USB ports in the console (I think the one on the passenger side) is the one to use and Carplay starts automatically. The other USB port in the console is power only (or at least it's not for Carplay).
Old May 3, 2021 | 09:34 AM
ihbond's Avatar
w222 s560
Hi AbbyKay;
Thanks for the reply...
Was looking for a specific rim, offset, etc etc tc due to the 20" AMG staggered setup with bigger brakes.. So I tried to search before I wrote the thread..
As for the CarPlay, yes I know there is a USB, but that is not wireles (which I am looking for) as far as car play goes (Maps etc etc)...THe wireless dongle I posted I believe works over WIFI, and prefer Bluetooth as I do work from the back of the car from time to time, and need driver connected...
Old May 3, 2021 | 10:36 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Since wireless Carplay wasn't even an Apple option in 2017 when the facelifted 2018 S-class was introduced with Carplay, MB didn't add it to future years as the tech in COMAND never really gets updated after a new model or facelift. I'm sure it will be standard in the W223 through since it's an all new model. You'll need to purchase a WIFI dongle and plug it into that port in the armrest in order to have wireless with iOS 9 or later.
As far as replacements for the crappy RFT's, do not downgrade to 19" wheels and instead put these tires on your 20's. They are fantastic!
Old May 3, 2021 | 12:01 PM
2012 merc amg's Avatar
2018 S560
I tried the airplay dingle and it did not work very good it would frequently cut out and not boot up and that kind of thing I returned it.
Old May 3, 2021 | 07:49 PM
ihbond's Avatar
w222 s560
thanks..sounds like a integration inconvenience...I would probably just walk away , as I have heard this from others as well..
Old May 3, 2021 | 07:51 PM
ihbond's Avatar
w222 s560
will look in Continentals. see which one has a better stock . I do quite a bit traveling and having a tire available from like Les Schwab or whomever readily available in the warehouse, is appealing to me...
I still have heard good things about Bridgestone...
Old May 3, 2021 | 11:18 PM
MBNUT1's Avatar
2010 E350 4Matic
Yes one of the members here is quite happy with his Bridgestone QuietTracks.
Old May 4, 2021 | 07:57 PM
ihbond's Avatar
w222 s560
Thanks!
Old May 6, 2021 | 10:30 AM
ihbond's Avatar
w222 s560
So after looking into a spare tire for s560 Quatromatic..I was able to find one person that offers a spare that should work with the specs...(unfortunately, you still have to remove the original tire and place it in the trunk)
I would fall into the 20" tire size for 2020 s560 with AMG 20" staggered rims..as my measurements to top of the trim are 29 and 29 3/4"
"Hi XXXXXX, I have attached screenshots so you can view the comparisons of the rolling diameters so you can see how our spare tires match up to your 2 sizes of OEM tires. Mercedes allows up to an 8% variance between the OEM tire and the temporary spare's rolling diameter, we are well below this on both of our 20" tire sizes for your car.
I am recommending you go with our 20" alloy wheel with the tire size 145/60R20 because of it's size & I know for sure it will not bump up to bottom of the trim that is right above the tires on the vehicle. The 195 size tire is taller and I think will be too close to the trim, you may want to measure and see if 28.4 inches falls at least 1 inch below the trim. If it does, you could go with the 195 tire and this spare is $359.00 plus tax and shipping. The price of the 20" with the special Continental tire size of 145/60R20 is $499 plus tax and shipping. This tire has a 15,000 mile warranty and can be driven at normal speeds and distances, same as the Toyo tire. "
Old May 6, 2021 | 12:01 PM
DaveW68's Avatar
Veteran: Army
2015 S550
All you bunch of worrywarts out there thinking your tires are all of a sudden going to blow out is a bit neurotic. In 37 years of driving, it's only happened to me once about 30 years ago when I hit a piece of rebar on the highway in my old Probe GT.
The tire goo and air pump will take care of 99% of flat tires. In fact, it is extremely rare that you'd even need the goo as most leaks are slow and you'd be able to make it to a tire shop for repair by just adding air. And in the very rare instance where some major impact trashes the tires, that's why you have MB roadside assistance or AAA or whatever. Spending lots of money on some crappy spare tire solution that takes up valuable trunk space is very silly IMO.
Old May 6, 2021 | 12:29 PM
drose224's Avatar
2017 S 550
Ditched my run-flats as fast as I could. New tires are Bridgestone Turanza Quiettrack. So far these tires are unbelievable. Quiet and the ride is smooth and luxurious the way an S class should ride. Years ago I had a BMW Z-4 with run flats and my wife refused to ride in the roadster until the ride improved. Since then got rid of run flats on any car I've bought. Usually the dealer will swap them out for non run flats. Worry about flats? Not me. Although I do keep a small 12V compressor in the trunk. I've only experienced one slow leak in seventeen years. Since 2004 I've been run flat free and have never had a flat in non-run flat tires. Would never take up the space in my trunk with a spare tire. Living vicariously without a spare tire.
Old May 6, 2021 | 12:38 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
Dave, That has been my experience also. My first reaction to the new "no spare" configuration was one of concern because I'd always had a spare tire as part of the basic configuration. But after thinking about it I realized that I haven't had a spare tire out of the trunk since the '60s.
Old May 6, 2021 | 12:56 PM
ihbond's Avatar
w222 s560
Hi Davew68..Ya jinxed us now.. (Playing around)
To be fair. my Older Mercedes had 2 flats in one week ( then my truck (never had a flat). Mustang never had a flat, Mercury Cougar 2 flats on one road trips.So
I do travel some distances where roadside is either via CB or satellite Phone. So driving longer distances may require some comfort of a spare..
AT VERY LEAST A JACK! that way if I need to plug the tire, it sure helps to remove foreign debris and plug away.
"Statistics also show that every driver will experience on average up to 5 flat tires in their life time. So the likelihood of running into such a roadside emergency is very high." so maybe Just one more flat in my life and I am all good
Old May 6, 2021 | 02:23 PM
LAWYER2's Avatar
15' W222
Never understood how run-flats were supposed to help you when you're a hundred miles out from civilization. It's one of the main reasons I've never taken my Mercedes (or my past BMW) on a road trip. What's the logic behind eliminating the spare, are people driving further distances less often these days?
Old May 6, 2021 | 02:41 PM
Fred2's Avatar
Sprinter, agate grey sports car, e350 Wagon, S
Pretty much every motorcycle on the road today does not have a spare tire, and that does not stop them from traveling
Old May 6, 2021 | 03:39 PM
ihbond's Avatar
w222 s560
such a different beast, the tires are thicker. especially on the side...blowing out a side wall is usually unheard of. when we did have flats, we filled the inner tube..But now with tubeless you limp along most shops carry the tire even independents.....
I have had more Car flats then MX flats...
TO your point though..yea...when you do get a flat you get a flat...and can even be more dangerous on a MX especially in the HIGH HEAT, and not being near anywhere... but most MX trips are usually with a buddy or a few folks on longer distances...
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
