S-Class (W222) 2014-2020
W222 Raised Transport Mode
Old Feb 27, 2022 | 11:59 AM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
Transport Mode raises the vehicle even higher than the standard vehicle raised height mode on W222 Airmatic equipped vehicles. This mode would assist the front air dam in clearing a tilted roll back transport deck, train ramp or similar.
I tried this mode and snapped a few photos of the results. Looks like it could help get you out of a stuck high-center, high water, deep snow or if you had to get a jack under the vehicle if off-road. Probably could help elderly persons enter & exit. Its takes a few minutes to raise and lower to & from the transport height so be patient while it transforms if you try it. Maximum speed is 20 MPH or 32 KPH. I did not try to drive in this mode yet.
With the engine running, to start you need to be completely in the standard raised position after you have short pressed the raise vehicle button with the vehicle in "P"ark.
After the vehicle finishes its standard Vehicle Rising ^ phase, you long press the raise vehicle button for 5 seconds. There will be no indication that it is raising further other than the noise of the air compressor running and the air strut valves engaging and releasing as the vehicle raises around the 4 corners. After it completes raising to the transport mode, the raise vehicle button's red LED will be flashing. There will also be a message in red on the dashboard stating Max. Speed 20MPH with a red outline of a vehicle & a down arrow.
To lower the vehicle out of transport mode, long press the
raise vehicle button for 5 seconds, Again this takes to awhile to lower from this height.
W222 S-Class Cross-Over...
Mud Flaps/ Splash guards on order.
Old Feb 27, 2022 | 01:16 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Wow, great find! Is this even in the manual?
Thank you for bringing this to our attention. It certainly can be helpful in many of the situations you mentioned.
Old Feb 27, 2022 | 03:58 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Incredible Find!!! If it works on my 14', this will help tremendously. When I do Oil Changes, Brake Bleed etc, I usually drive up on 4 Ramps
Amazon.com: RhinoGear 11912ABMI RhinoRamps MAX Vehicle Ramp - Pair (16,000lb. GVW Capacity) : Automotive Amazon.com: RhinoGear 11912ABMI RhinoRamps MAX Vehicle Ramp - Pair (16,000lb. GVW Capacity) : Automotive
But because of the restriction of the rear, I cannot slide the ramps under due to the low clearance. I have to drive up partially on the front two, then press the emergency brake, put it in park, then place the 2 additional ramps under the rear wheels, then finish driving up on the fronts. This will solve my problem and give me incredible scootch around height and the safety should the bladders leak while I'm under there.
Really cool find! Will test.
Old Mar 1, 2022 | 12:06 PM
Please, always use suitable jack stands before working under any vehicle. I would not trust a lifted air suspension to hold its raised position. Thanks
Old Mar 1, 2022 | 06:09 PM
Nice Ride's Avatar
Please, always use suitable jack stands before working under any vehicle. I would not trust a lifted air suspension to hold it raised position. Thanks
Yes, I agree 100%. What I had mentioned also is that the car is on 4 ramps way overrated for the capacity of the car. Thank you for pointing out Safety First! I had a friend many years ago who was working on is car with a bottle jack, he was on a creeper under the car, The jack had a small leak, the car had lowered so slowly, he had no idea. He ended up getting pinned under the car for several hours until his wife came home to get help. Thank goodness the car did not go any lower, he had trouble breathing and his head was sideways unable to move.
Safety . Safety . Safety. Thank you again for pointing it out.
Old Mar 1, 2022 | 07:13 PM
2012 merc amg's Avatar
2018 S560
I tried it on my 2018 with MBC and it's a no go. I kinda figured with the MBC it wouldn't work but had to try. The Raise mode works ok but nowhere near as high as your car in the pic. in Transport mode. That would be good for off roading, lol
Old Mar 1, 2022 | 07:33 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Huh, wow! Learn something new every day
Old Mar 2, 2022 | 12:29 PM
I would assume transport mode max's out the raised air suspension so I wouldn't recommend repeated use ⛔️ 😉
Old Mar 2, 2022 | 12:43 PM
Scorpion006's Avatar
2011 Mercedes Benz E350, 2007 Toyota Tundra, 2007 Honda CBR 1000 RR, 2015 Porsche 911 Turbo S
I just tested this yesterday - pretty awesome. Even the dealer (sales) didn't know about it...
Old Mar 2, 2022 | 10:58 PM
Nice Ride's Avatar
What year is your car?
Old Mar 3, 2022 | 02:18 AM
BenzV12's Avatar
W212 FL
That's something I was not aware of either
Thanks for sharing . I didn't know W222 could raise that much at all
Old Mar 4, 2022 | 01:31 AM
I was looking at a 2018 S560...
Old Mar 6, 2022 | 10:25 AM
Yes, in the 2019 US issued S-Class manual 2225843910 under "Transporting" pages 420-421
Old Mar 6, 2022 | 01:14 PM
konigstiger's Avatar
'71 Pinto
Started 2018, MBUSA manual:
Old Mar 6, 2022 | 04:23 PM
Nice Ride's Avatar
Started 2018, manual:
Does not work on my 2014 W222 4Matic. Anything special that needs to be done? Would love to get that to work so I can drive up on the 4 Ramps I use....
Old Mar 9, 2022 | 11:00 PM
Nice Ride's Avatar
What year did this get implemented? Is there a way to raise it with programmer for maintenance?
Old Jul 29, 2022 | 09:12 PM
mercedesbuff's Avatar
'20 GLS450, '17 S550 Sedan
"Transport Level" -- Works on 2017 (pre-facelift)
I stumbled upon this "Supplement to the Operator's Manual," for my 2017 S550 (pre-facelift). Not sure if 2017 was the first year "Transport Level" was operational or not.
I tried it, and sure enough, the car went freakishly high. I don't have any immediate plans to ford a river, but if I do... I'll make sure to stay under 12 mph.
Here is the one and only page, from the Operator's Manual Supplement (part# 222 584 66 06):
Car raised to "Transport Level":
Car lowered back down to "Normal Level":
Happy Motoring!
Old Jul 29, 2022 | 10:23 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Adaptive Damping Plus? Was that a standard feature or an option?
Old Jul 29, 2022 | 10:41 PM
I believe Adaptive Damping PLUS was standard, coupled with AIRMATIC. The optional suspension was Magic Body Control.
I can say with certainty that my car does not have Magic Body Control, so I have the "standard" suspension setup.
Old Jul 31, 2022 | 09:17 AM
jbarhorst's Avatar
2018 S450 4Matic, 2020 GLE450 4Matic, 2010 S550 4Matic(sold), 2012 ML350 4Matic(sold)
I found it interesting that in the 2017 manual they tell you to deactivate transport mode and THEN drive off the transporter.
Probably just a mistake.
Old Mar 5, 2023 | 04:31 PM
Nico9182349's Avatar
W222 S560 4matic 2018 and C140 CL 500 1998
Here it is digitally as well https://moba.i.mercedes-benz.com/bai...9cf-en-GB.html
Old Mar 7, 2023 | 01:56 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
I tried it today.
very cool for going over curbs.
