S-Class (W222) 2014-2020
2018 S560 interior trunk space...
Old Apr 24, 2024 | 06:01 PM
Lou B's Avatar
Veteran: Army
Mercedes S560
My apologies for this question, but I cannot get to my 2018 S560 to check it out.
I'm looking at getting an electric scooter, that when folded measures 40" long, by 22" wide, by 18" high.
Will this fit into the trunk of my car?
Thanks to all assisting!
Old Apr 25, 2024 | 12:23 PM
Lou B's Avatar
Veteran: Army
Mercedes S560
OK, thanks, anyway - don't blame anyone for not being interested.
I measured it - due to angles in sides and top of trunk lid, it may be possible, but only way to tell is to buy the scooter and try it!
With a 3o return, we'll see how it goes.
Old Apr 25, 2024 | 11:36 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Also note there are 4 sizes of trunk so even if someone was inclined to try to measure they don't know what trunk you have.
Old Apr 25, 2024 | 11:47 PM
BenzV12's Avatar
W212 FL
I have not tested an electric scooter in the W222 S Class, but W205 is able to get it .I assume you don't have refrigerator otherwise I would advise you to remove it
Old Apr 26, 2024 | 09:03 AM
Lou B's Avatar
Veteran: Army
Mercedes S560
Nope, no refrigerator.
Wow! Truly?? The 2018 S560 4-door sedan standard backseats was made with four different size trunks?!?
I never would have dreamed that! Keep learning stuff everyday!
I've ordered a Solite scooter, and have found a similar one that is a trifle smaller and a bit less expensive. We'll see.
Old Apr 26, 2024 | 10:00 AM
vincheung's Avatar
S63, GLE580, BV250
It will fit, my car has less trunk space with the reclining rear seats & 3D sound. I throw my old Xiaomi M365 in the trunk from time to time folded measurements are 108 x 43 x 49 cm.
Old Apr 26, 2024 | 10:41 AM
Lou B's Avatar
Veteran: Army
Mercedes S560
108 x 43 x 49 cm = 42.5 x 16.93 x 19.29 "
Will have to check - the trunk sides angle inward going back into the trunk, and the trunk roof slopes downwards toward the front loading edge. It's the trunk width across at a point 19" in from the opening inner edge, and the trunk height at the inner trunck edge where it may not.
Inn other words, the trunk cube narrows as it goes back from the loading edge, and shrinks down from the rear of the trunk to its front.
Thanks for your data!!
Old Apr 26, 2024 | 11:31 AM
Lou B's Avatar
Veteran: Army
Mercedes S560
this
Also - the folded scooter itself does not provide a perfect cube, but one that tapers in length rear to front. Another reason why I have to see if it will fit in..
Old Apr 26, 2024 | 11:33 AM
vincheung's Avatar
S63, GLE580, BV250
I might have to take it out for a spin later this evening, if I do i'll throw it in there and snap a pic at how I have it oriented. Does your vehicle have reclining rear seats?
I just realized we are talking about two different types of scooters Lou! Im referring to the little two wheelers. Regardless, I actually may have a large box that is about or slightly bigger than the specs you have listed, if so I can place it in the trunk and snap a pic for you.
Old Apr 26, 2024 | 01:13 PM
Lou B's Avatar
Veteran: Army
Mercedes S560
So much for communication in the same language!!!! Definitely my fault!
Loo
I'm never successful at posting photos here, and it won't let me paste the URL link (Wonder why?).
Look up " ZiiLF R3b " Lightweight 4 wheel scooter by Zobot - should find it.
Old Apr 26, 2024 | 08:37 PM
vincheung's Avatar
S63, GLE580, BV250
@Lou B, I had to move a semi-large box today and snapped two pics and also took a look at your scooter's specs. Height and width wont be an issue especially if you do not have the "magic box" installed (even if you do, it can be removed).
Height you have a solid 22-23 inches so thats all clear, width (carpeted side to carpeted side) you have a little over 38 inches, the only concern would be the depth of your trunk (mine is about 33 inches deep), if you do not have the reclining rear seats & 3D sound, the scooter should fit just fine. Ideally loading it would be putting in the front wheel first touching the back seats and rear wheels last. If you measure the depth of your trunk from rear seat to bumper and its over 38, you'll be golden.
I would recommend getting a trunk/bumper flap so you don't need to worry about any damage to the bumper & paint placing and removing the scooter plus it'll be easier to slide in and out, the third pic is the type of flap i'm referring to. (https://amzn.to/3JzmSCG). I got one for my old timer neighbor and worked well for his sedan.
Old Apr 27, 2024 | 09:41 AM
Lou B's Avatar
Veteran: Army
Mercedes S560
Thanks so much for your efforts and suggestions.
Had not thought of insert the scoooter in nose first, only crosswise.
Have found the bumper flap on Amazon - many thanks.
Old Apr 27, 2024 | 09:56 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
The size of the trunk depends on::
a) do you have a refrigerator
b) do you have the executive seat option
c) both
d) neither
Old Apr 28, 2024 | 09:31 AM
Lou B's Avatar
Veteran: Army
Mercedes S560
c) both
d) neither
Really?
Who would have thought that?
You don't think I would know if I had a refrigerator in my trunk?
My scooter is scheduled to be delivered tomorrow - we'll see very shortly.
Old Apr 30, 2024 | 01:48 PM
Sactownmb's Avatar
MY 18 S450V RWD Diamond White
Lou, the drop down package carrier at the top of your trunk can easily be removed.
Old Apr 30, 2024 | 04:23 PM
Lou B's Avatar
Veteran: Army
Mercedes S560
Thanks.
Can anyone tell me jow to get a larger point size type up here for the messages I recieve and write, please? My vision just cannot cope wit h these small type faces,
The scooter fits in the trunk cross-wise just fine. All I need is help putting it in and removing it and I'm home free.
All suggestions m
uch appreciated..
Old Apr 30, 2024 | 07:26 PM
vincheung's Avatar
S63, GLE580, BV250
Glad it fits Lou. You can fashion up a pulley system with the hook points at the rear corners of the trunk or maybe some accessible hooking points along the ceiling of the trunk. Some basic carabiners and nylon rope will make it easy to pull it up into the trunk and you can remove it the same way. Check out this youtube video at about 1:20 or so for the general set-up
. Make sure you have a bumper flap down as pulling the scooter up will be rubbing against it and/or add a lightweight board to have the pulley action go up at an angle. If i have some time later today or tomorrow I will try to snap a pic of how i would set it up.
The way I would set it up is two smaller carabiners for the corners (you don't really need it if you just tie it firmly to the anchor point), and one large hook for you to hook onto the lifting point of your mobility scooter. I threw some product links to make it easier if you decide to go this route.
Small carabiners - https://amzn.to/4dhfpWt
Divers reef hook - https://amzn.to/4aXdGnQ
Paracord/Rope - https://amzn.to/3Ws3KhP
Old May 1, 2024 | 10:03 AM
Lou B's Avatar
Veteran: Army
Mercedes S560
Glad it fits Lou. You can fashion up a pulley system with the hook points at the rear corners of the trunk or maybe some accessible hooking points along the ceiling of the trunk. Some basic carabiners and nylon rope will make it easy to pull it up into the trunk and you can remove it the same way. Check out this youtube video at about 1:20 or so for the general set-up https://www.youtube.com/watch?v=oGgCaFTcbHk . Make sure you have a bumper flap down as pulling the scooter up will be rubbing against it and/or add a lightweight board to have the pulley action go up at an angle. If i have some time later today or tomorrow I will try to snap a pic of how i would set it up.
Thank you for your continued interest and suggestions. I've long understood the functioning of pulley use, but the video did a good job of explaining it to those unfamiliar with it.
My wife and I easily lifted the scooter
into the S560 trunk - it will stay there until I decide where and when I want to use it. I'm really not interested in installing any sort of a pulley or other lifting system into my car. It's just not necessary right now.
Appreciatively, Lou B.
