s560 4matic or not?
my decision come to 4matic,
I live in California, occationally travel to Seattle.
how 4matic affecting driving on dry road? will it make driving better even on dry road in California?
thanks
AWD driving dynamics are not as engaging/fun, one of the reasons I decided to get the 65 and not the 63. Though admittedly for an S class driving dynamics are not that big a deal, it's still an unnecessary increase in mass, maintenance and fuel consumption.
Also with RWD you can get the fully active suspension (ABC) which is a completely different class than the air suspension everyone uses.
Exactly what problems do the 4matics have? The diff is rock solid and you almost never hear of any problems with the AWD components. And maintenance is dirt cheap with only a cheap diff fluid swap every 75k miles.
Sure...you can get Magic Ride in the RWD models as a rare and expensive option. But the failure rates are fairly high and extremely expensive with the ABC system as the miles are packed on.
Reliability for ABC in the w222 is actually good, the w221 is another story.
Regardless it's all worth to drive through a speed bump like nothing.
- 487 - MAGIC BODY CONTROL
- 463 - Head-Up Display
- 398 - MAGIC SKY CONTROL
Magic body control:
is that mean it has the so called "ABC" suspension
thanks
I've honestly never seen a specific 4matic issue ever pop up in the W222 board.
The 4matic is 0.1 faster than the RWD so not that you'd notice.
Post your opinion but please refrain from bringing trash politics into the forum.
Jobs like replacing motor mounts are far more costly on 4Matic cars because the driveshafts are in the way. Several other services are similar.
There’s no comparison to our E90 BMW which spins a tire and then brakes itself almost to a stop, if heavy throttle is applied while trying to turn at an intersection. The Benz just goes - quickly and effortlessly.
That said, the confidence that comes with 4Matic offsets the potential additional costs in my opinion.
In the end, the question is really: what are YOUR priorities?
Yeah, I would bet fully 80% + of the S out there are 4Matic....so, there ya have it. Plus, on the second hand market it opens opportunity to sell as anyone who is in a area with "Winter" would want the all wheel drive.
My 2019 has this combination and yes, must be very rare!
BTW, to try to help with terminology, "ABC" refers to the self-leveling suspension design of all W222s. If it's an "Airmatic" car, it's an air suspension. "MBC" cars are a different form of "ABC" wherein the suspension uses hydraulic fluid rather than compressed air.
The 63s have airmatic and can only adjust height and change dampening/spring rate. No curve, no prediction, no always flat on corner, no avoiding pitch on acceleration/brake, etc.
RWD Service- Change rear diff fluid, Engine mounts are a pain, but doable
AWD Service- Rear diff, front diff, transfer case. Engine mounts are probably engine out.
But for the OP; like others have said, it really does boil down to priorities. Nobody "needs" anything these cars offer, but it sure is nice to have something that provides a better experience. But you get to define what "better" means.
The 222 S-65 with MBC weighs less, has more power, more ratios in the transmission with electric steering that killed steering feel that I loved in the 221 car.
ABC Sport mode in the 222 car firms it right up. Never any body roll in all modes. Love watching others on rough roads get tossed about in their cars as the MBC car is smooth as can be.
AWD? Never felt the need.
