S-Class (W222) 2014-2020
Thermostat Price Insanity?
Old Apr 24, 2025 | 03:19 AM
S-Klasse MB's Avatar
S560
I have a 2020 S560 sedan. I'm getting a check engine light, which when read, is code P0128. I'm guessing this likely means the thermostat is going bad? Is there a way to tell if it's just the sensor instead? I went to look for where to order a new thermostat and pricing, and it seems like the thermostats are only sold as the whole housing? Is that right? Wondering if there's an aftermarket option for just the thermostat, but haven't found one yet. I was floored to see a $745 price tag for a damn thermostat housing, with no option seemingly to order just the thermostat by itself. Anyone have any experience with this and recommendations?
Old Apr 24, 2025 | 11:18 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
Thinking about this one I would say your engine is certainly not overheating since the code is indicating that its too cool on the coolant temp. I think if it was my car I would clear the code and see if it comes back. My thoughts are there is no damage to come from this and it could have just been a computer flub. Not the first time I have had to reset the Benz computer for something or another.
Old Apr 24, 2025 | 11:45 AM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
The M273 motor generation before these DI motors introduced the electronic thermostat. So yeah. all generations of the V8 from 2007 and later have an electronic thermostat and it's not cheap to replace.
Old Apr 24, 2025 | 08:00 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
The ideal operating temperature for an automotive engine is 212ºF water and closer to 230ºF oil.
Cooler operating temperatures lead to <slightly> more wear*:
a) as the oil may not be thin enough to provide cleaning to the piston ring package.
b) the oil may not be out-gassing its water-vapor
c) the engine parts dimensions may be slightly out of size/shape**.
(*) 1 hour of that temperature is nothing close to the wear of a single cold start-up.
(**) unless the engine break-in was done at those lower than engineered temperatures.
{{This is simply data I got from Bob-Is-the-Oil-Guy.}}
Old Apr 25, 2025 | 12:09 AM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Bad news
The labor to remove and install a thermostat on the 176/177 will make you forget about the cost of the part.
Old Apr 25, 2025 | 12:15 AM
VII's Avatar
VII
Also maybe good news
There is a warranty extension for that problem from MB USA.
Old Apr 25, 2025 | 04:58 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
It’s too bad that the insanely priced tag, only goes in one direction.
Because on the other end of extremely overpriced, is the extremely cheap.
For an item or product to be insanely priced inexpensively, it would have to be stolen property, somehow fraudulent, or found at a garage sale after endless searching.
Old Apr 25, 2025 | 10:10 AM
ajm0623's Avatar
'25 740i; '15 targa4s; '24 cayenne
yep. i had the same issue on my '20 s560. took it to the dealer and waited 10d or so to fix. tear the engine down 'to get to it' then many days of bringing the engine up to temp and letting it sit to cool down and test and retest. it's a long-assed process. don't know about $ as my was warrantied, but i can only imagine the cost of this outside the warranty given what it took to fix this relative simple kit.
Old Apr 25, 2025 | 04:34 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Thermostat is a HUGE job on this car
Old Apr 25, 2025 | 05:16 PM
xabo's Avatar
'20 S63
Car was in the shop for about a week. Covered under warranty.
Old Apr 25, 2025 | 05:22 PM
W205C43PFL's Avatar
https://cimg9.ibsrv.net/gimg/www.mbw...a4855e0198.jpg
Thanks for sharing the RO, what does excluded from media reporting mean and what does UCD stand for?
Old Apr 25, 2025 | 05:57 PM
xabo's Avatar
'20 S63
No idea......two of the wheels had curb rash when I purchased the vehicle. Thermostat went out after about Two (2) weeks of owning the vehicle.
Old Apr 25, 2025 | 06:46 PM
W205C43PFL's Avatar
Hmmm, might be a coincidence then.
Old Apr 25, 2025 | 09:32 PM
JohnLane's Avatar
222 S-65
Damn.... Another perfectly good reason to drive a bent-12 powered car. Old school wax pellet thermostat that is utterly reliable and inexpensive to replace if needed.
FWIW every manufacturer using Disney thermostats has the same issue and they are all D-U-M dumb priced + ridiculous effort to replace as somehow the thermostat housing includes many connections for hoses that go all over the damned place in search of problems. Then we are shocked when that plastic junk breaks cuz well... plastic in the cooling system is such a fine idea.
Old Apr 25, 2025 | 09:55 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Engineered for performance, not for servicing.
Old Apr 26, 2025 | 09:37 AM
W205C43PFL's Avatar
Price to pay yes but you do get the creature comforts and luxury amenities a W222 provides, once it is out of the shop.
S class is an S class.
Old Apr 26, 2025 | 10:33 AM
Turboaction's Avatar
2015 S600, 2014 E550 4-Matic
This issue was ultimately what steered me to purchasing another S600 vs one of the other V8 options. I scanned the codes on the one CLS63S I test drove and it also had a failed thermostat. My wife already has an M278 V8, and I'll spend plenty of time replacing plastic parts on her car. The V12 is an antique, but it's a well-crafted antique, with continuous improvements over the generations.
Old Apr 27, 2025 | 06:51 PM
MBNUT1's Avatar
2010 E350 4Matic
Note to self. Remove S560 from consideration of a used car purchase. I redid my E-Classes thermostat and flushed the system one Saturday morning. Doubt it cost me $100.
A friend of mine had a new GMC pick-up truck which needed it's thermostat replaced and it took a couple of days of labor to tear it apart and put it back together. Can remember my friend asking "What genius millenial engineer thought that was a good idea?"
Old Apr 27, 2025 | 09:53 PM
SW20S's Avatar
2024 S580
You gotta pay to play. Get a warranty.
Old Apr 28, 2025 | 12:26 AM
JohnLane's Avatar
222 S-65
You gotta pay to play. Get a 279 V-12 powered car.
Fixed that for you friend.
Old Apr 28, 2025 | 12:28 AM
The M275 and M277's aren't too bad either. If you're going to spend $1K on the engine repair, it might as well be for a mind-bendingly complicated ignition coil or voltage transformer!
Old Apr 28, 2025 | 12:36 AM
JohnLane's Avatar
222 S-65
277 is a bent eight isn’t it?
Your 222 has a 279 with individual coils. No more coil pack and voltage transformer drama we got to deal with in a 275 powered car.
Old Apr 28, 2025 | 06:54 PM
MBNUT1's Avatar
2010 E350 4Matic
Happy to pay for engineering excellence. IMHO this isn't that.
Old Apr 28, 2025 | 09:34 PM
SW20S's Avatar
2024 S580
What you have to understand is this car (and every other car like it) is designed for performance first, and repair and maintenance cost second. It's not designed for you to buy it when its 5 years old and drive it until its 15 years old and not have to pay for any repairs. That's a Lexus ES. You can't even expect that with a Lexus LS (I know, I've had 4). If you are concerned about maintenance cost, no car like this is for you that's just the bottom line. Just get a warranty, or just be happy with a much less complex and more reliability focused car.
Old Apr 29, 2025 | 02:15 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
damn I thought my M278's thermostat was expensive, this is 2x and then some! I knew it was a 222 thread though before I clicked it one way or the other
the physical thermostat doesn't break, the seal between the electronics and the not-electronics gives and you end up with a fault where it stays open by default, These have been a pain in the *** since the earliest MAP thermostats. I remember when the M273 came out people were pissed that they were $100+ and not the lil $12 duders that sit in the hose connection
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
