S-Class (W222) 2014-2020
MBC
Old Jul 4, 2025 | 03:30 PM
Paalig's Avatar
W211 220 CDI, W212 220 CDI, W222 560
MBC
When i drive the right side of the car is always lower than the left. Anyone who has experienced the same thing?
Old Jul 4, 2025 | 05:23 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
That is not lower, that is force intervention. But yes that is not normal unless you are of a very heavy construction.
Old Jul 5, 2025 | 05:23 AM
Paalig's Avatar
The left front wheel also gets a few degrees warmer than the other wheels. What could be the problem? I'm not fat as ****😂
Old Jul 5, 2025 | 07:57 AM
VII's Avatar
VII
I would start with a verification of geometry together with diagnostics to verify range of actuation then check alignment if everything looks OK.
Old Jul 5, 2025 | 03:00 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
On my MBC car the right front tends to be about 1/4 - 3/8" lower than the left (measuring from the fender lip to the ground). Tire pressure and plenty of other variables could be involved ...
Old Jul 5, 2025 | 03:39 PM
Paalig's Avatar
Do you see the same as I have posted in the picture if you find that menu in the car? You can see in the photo that the right side of the car has more load
Old Jul 5, 2025 | 09:29 PM
No, sorry., not familiar with that screen
Old Jul 6, 2025 | 06:13 AM
Paalig's Avatar
You go to «car» and then «cardata»😊
Old Jul 10, 2025 | 02:18 PM
VII's Avatar
VII
This is the normal state with one person in driver seat.
Old Jul 10, 2025 | 04:09 PM
Paalig's Avatar
Mine is the same as yours when I'm standing still, as soon as I start driving it's like I posted in the picture
Old Jul 10, 2025 | 04:25 PM
VII's Avatar
VII
That is the same state you should see driving straight in level ground while coasting.
You might have an accelometer issue, best bet to get diagnostics to look at actual values of inputs.
Old Jul 10, 2025 | 04:45 PM
Paalig's Avatar
Yes, i have to get diagnostic
Old Jul 11, 2025 | 07:53 AM
Digital Oxygen's Avatar
One of them there S cars
Does the level change when driving? On mine, I occasionally see the yellow drop a... coil? line?... or two, for less than a second at various corners. Usually happens after a bump or road imperfection.
Old Jul 11, 2025 | 10:10 AM
Paalig's Avatar
Mine is like in the picture as soon as i start driving. Allmost full yellow at the left front and barely nothning on the right. In corners and bumps it drops as normal
Old Aug 5, 2025 | 11:52 AM
Paalig's Avatar
The workshop has now changed the level sensor on the left front. I can still see that the load changes in the dynamic select menu as soon as I start driving. It looks normal until the car starts rolling. Then it jumps down a few levels in the dynamic select menu.
Old Aug 5, 2025 | 11:58 AM
Paalig's Avatar
Here I first stand still, then I start driving and then the level immediately drops. This is on a completely flat concrete surface.
File Type: mov
Old Aug 5, 2025 | 12:02 PM
VII's Avatar
VII
Again that is NOT lower.
That is higher force intervention attempting to raise that corner.
Actual values need to be reviewed on why the system sees the need to push to raise that corner.
Old Aug 5, 2025 | 12:23 PM
Paalig's Avatar
I know its not lower. But you can see in the video the force intervention drops on the right side as soon as the car starts rolling. How is yours when you start driving? Does it change as mine does?
Old Aug 5, 2025 | 12:27 PM
VII's Avatar
VII
No, it will stay the same while driven on flat, even pavement.
Something is off with your system, the force intervention is too high on all corners as well as the discrepancy side to side.
Old Aug 5, 2025 | 12:43 PM
Paalig's Avatar
I have been to a workshop and spent the equivalent of 2,500 dollars in Norway, where I live. They have replaced a support arm that was loose and the level sensor on the left side. Do you know of anything I can try, or do you know how to use the star diagnosis to find out what is wrong?
Old Aug 5, 2025 | 01:43 PM
VII's Avatar
VII
I know how to use it but I'm in Texas.
You need someone who is familiar with the system or can read the documentation in WIS.
Then after verification of suspension geometry and mechanical condition, with Xentry you look at the actual values. What inputs is the system getting and what outputs is it commanding; use this to locate where the anomaly is coming from.
It could be a problem with the system, such as a malfunctioning shock or valve block or an incorrect input from a malfunctioning sensor or control unit.
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Too much information can result in imaginary problems.
Old Aug 5, 2025 | 01:44 PM
VII's Avatar
VII
And ignoring symptoms leads to more expensive problems or dangerous outcomes.
Old Aug 5, 2025 | 01:57 PM
Paalig's Avatar
Thank you very much for a good answer! Too bad you're in Texas, a bit far for a diagnosis😂 I'll try to find someone competent to look at it
