The end of Hydraulic ABC for the S-Class
It seems the new W223 chassis has foregone the hydraulic ABC system form the e-active ABC system.... is this correct?
Is this the end of the Hydropneumatic suspension from Mercedes?
Super Moderator
Received 3,186 Likes
ABC (actually MBC) as a hydraulic (oil) suspension is gone for the S-Class. All suspensions, including the E-active suspension is based on Air, so ALL S-Class suspensions are Air suspensions. MBC was limited to rear wheel drive systems only and E-active has more features/capabilities
The following 2 users liked this post by Wolfman:
SilberGrau57 (09-03-2020),
Streamliner (09-04-2020)
How is MBC technically ABC? I have never heard it called MBC
Super Moderator
The W222 introduced MBC (Magic Body Control) which is technically the ABC (Active Body Control) suspension we know from other Mercedes models paired with two windshield cameras and software to provide forward-looking road sensing ability to adjust the dampers for a smoother ride. Cool by concept but hampered by limitations (only use during daylight, comfort mode and rear wheel drive cars) in addition to some software quirks. E-active suspension eliminated these limitations...
chassis (09-05-2020),
Super Moderator
Not quirks as much as a too narrow set of conditions when the "Magic" part of the body control is enabled. The suspension is supposed to adjust for surface imperfections or driving over speed bumps. All of the work is conditional, similar to how ECO start/stop kicks in if all conditions are met.
For example to drive smoothly over a speed bump, you must be in Comfort (Sport model disables it) mode and with the foot on the gas pedal. Instinct will have your foot on the brake pedal when approaching a speed bump. Braking deactivates the features; you must drive over the speed bump (albeit slowly) without braking.
This simply reduces some of the practicality. The latest version of E-active is supposed to have more leeway to keep features enabled.
OK, so it comes on top of air or what? Or simply takes its place?
You expect me to believe there's a small electric motor in each corner, squeezing steel springs and adjusting them accordingly in real time?
Because that's what they've been telling us all along...
Super Moderator
Google is your friend here. There are lots of videos explaining E-Active
Received 3,502 Likes
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
It’s interesting to note that EABC was an $8,200.00 option on the 2020 GLE SUV models, but was unceremoniously dropped from the option list for 2021. One year and BANG! Gone.
Super Moderator
It is available on the pricier GLS for $6500...
Super Moderator
Super Moderator
Keep in mind that this suspension has different feature sets as its in a SUV with off-road use...
I’m not wondering why the option is gone from the GLE, I’m wondering why it was there in the first place. I drove a GLE580 with EABC and was not impressed. They should have given the GLE an MBC option, for around $4K and I believe it would have been much better received.
Super Moderator
I can only assume that there was a point to pick the right suspension tech moving forward and oil lost to air...
We both are strong proponents of ABC and MBC. They are fantastic suspensions, especially over the last 7 years plus. But they have also been limited in its use (no AWD, no lift capability for SUV's). At the same time the latest Air suspensions have evolved to the point that they became the go-to choice for AMG's.
The demands on the 48V system for the eActive suspension will prove to be interesting from a long term perspective. Lithium ion batteries tend to hate 'high current' short draw demands which is what all of these electronic active suspension systems demand. No one knows how reliable or $$ they will be but time will tell.
Super Moderator
I must admit that the Air Body Control in my E450 wagon is very impressive, while the air suspension in the Bentley “New” Flying Spur that I test drove was disappointing, giving a sort of bloated, billowy ride. It will be very interesting to drive the W223 with EABC. Hope they get it right.
Here is some info on the S-Class E-ABC suspension. It is in German only but can be easily translated via Google translate, etc...
https://jesmb.de/3863/
So I just spent a little time reading about the suspension and there is a hydraulic component to the suspension. So it really is Air+Oil
Super Moderator
Super Moderator
