Car wash
Car wash
Does anyone have any advice for taking the car to a automatic car wash. I'm concerned when I get out of the car and it starts moving, I get locked out. Do I deactivate the key and hold it? or leave it in the car? What does everyone do about car washes?
Received 2,446 Likes
2020 S560 4Matic
You should always leave the key in it. Just like any other car
Yeah, but doesn't the car auto lock when it starts moving forward? If the key is in the car and it locks, there is no way to open the door since the handles retract. Or, are you suggesting it won't lock when the key is inside (they way my 2020 S560 worked)?
Received 2,264 Likes
PFL205.064 with M276.823
Sorry if I am confused but from my understanding this is a type of automatic car wash that you aren't allowed to be in the vehicle while it does its thing? The engine also has to be on? As far as I heard personally, if it is the guided ones (and the ones you actually sit in the vehicle), you put your vehicle in neutral and therefore I don't believe it should lock unless you are in drive but if you are using the guided tracks then you shouldn't be in drive anyways, you also shouldn't be turning your steering wheel while it is on the tracks as it can damage the rim and with rear wheel steering it would cause damage to that system as well.
2020 S560 4Matic
It should work exactly like your 2020 S560. When the engine is running, its in neutral and it starts to move, the doors wont lock.
Received 1,579 Likes
Mercedes/Mazda/Genesis
I don't think it should lock with the key inside your car, at least not in neutral. You can also disable the auto lock functions in the settings if worried. The handles may retract, however a simple swipe/push should rectify that and extend them again. If the key is in the car, and the car dies, even still I believe the handles are supposed to retract for emergencies so it can be unlocked with a physical key.
2021 S450 4Matic
Related thread
https://mbworld.org/forums/s-class-w...ck-list-3.html
Your reply, and those of others, seems to indicate this is no big deal, just treat like my previous S Class. However, I’m still confused about how the door handle will retract if the car is not locked and how to prevent other stuff from happening when the car starts moving on the belt (with me not in the vehicle). This is what the operator’s manual says:
“To avoid damage to your vehicle when using a car wash, ensure the following beforehand:
- Active Distance Assist DISTRONIC is deactivated.
- The HOLD function is switched off.
- The surround view camera or the rear view camera is switched off.
- The vehicle is locked and the door handles retracted.
- The side windows and sliding sunroof are completely closed.
- The blower for the ventilation and heating is switched off.
- The windshield wiper switch is in position
- The SmartKey is at a minimum distance of 20 ft (6 m) away from the vehicle. Otherwise, the trunk lid or a door could open unintentionally.
- Neutral i is engaged.
- The vehicle is locked from inside.”
This seems like a lot of work to wash the car. AND, HOW can you lock the vehicle from the inside if the car is going through a wash without the driver inside?
I would really appreciate some real life experiences from someone with a 2021 or 22 S Class?
2020 S560 4Matic
2020 S560 4Matic
They may extend, but that shouldn't impact the wash. Think about it this way, when the door handles extend its like any other car with always extended door handles.
With my W222 the front and rear cameras deploy in the carwash and nothing is ever an issue.
Thanks that makes sense. But, I would love to hear from others who have a W223 and have been through a wash. (I went to pick up something at the store the other day, left the engine running for a few minutes, came back and the handles had retracted, engine running and I panicked for a second trying to figure out how to open the door. Wasn’t a problem, as I could just run my finger over the handle. But there are so many warnings in the manual that I worry I’ll get locked out. LOL)
JSL555 (03-20-2022)
2021 S450 4Matic
Maybe one can think through the list, item by item, to figure out why MB puts them there. I reckon, most (if not all) are just safety precautions to avoid possible (though remotely) damages.
Say, the windshield wiper position is in ''0''. If not, the water would trigger the wiper to function during washing. This is obviously a good chance of having the wiper entangling the brushes.
Say, the blower for the ventilation is switched off. I imagine this is to prevent/minimize sucking in those foam soap mist into the ventilation duct.
Say, rear/surround view camera be switched off. This does not mean they are flimsy enough to get water damaged every single time. But, this possibly gives extra protection? Germans like to err on the side of ultra safety?
And, maybe just putting such a list in the manual can save a lot of repair money (warranty or not) even when only a very very small percentage of MBs get a car wash related damage.
