ABC pump failure - need help please
My questions are: Has anyone had success with the rebuilt ABC pumps that run for about $650? or a new one for $1100 instead of a dealership version?
Can anyone please help with instructions on how to replace the pump? I have been told that the fan has to come out to gain access to the pump and that apparently is also a pain.
Any help would be appreciated.
Just a thought.
Good luck. I replaced my own pump and it sucked.
You from Texas boi? You sure do a lot of Rodeo
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
