08 S63 blowin white smoke and shaking??
Old Sep 25, 2012 | 01:20 PM
pomoboy's Avatar
Took my 08 S63 in for and oil change, picked it up and drove about 5-10 miles and it started shaking really bad and blowing black smoke out. Had no oil and the dip stick had black charred stuff on it, guessing it was oil. Tried starting it up and it shakes crazy and blows white smoke. Took it to a few local shops and said I need a new engine! They really didnt look too much into it just went by the visual signs. Any suggestions? Thanks.
Old Sep 25, 2012 | 01:37 PM
Welwynnick's Avatar
2006 S600
Perform OBD2 dump and look at fault codes.
Change the oil, look for low level and contaminants.
Change the coolant and look for contaminants.
Perform compression test.
Remove cylinder heads.
Good luck
Old Sep 25, 2012 | 08:18 PM
mrbenzes's Avatar
2005 S55, 2002 E430, 2007 CLK350, 2006 SL55, 2003 SL55
take it directly back to the oil change guys and ask them why the drainied the oil out but didnt put any back in..they owe you an engine....
Old Sep 26, 2012 | 03:00 AM
sakodik's Avatar
E-Class
Wait, so you found there was no oil and then you started your engine up again?
Old Sep 26, 2012 | 03:37 AM
Rott's Avatar
SLK
Mercedes Benz 2008 S63 blowing white smoke and shaking
Mercedes Benz 2008 S63 No Oil in engine
Check this out…
pelicanparts.com/catalog/SuperCat/4225/MBZ_4225_ENGOIL_pg1.htm
Old Sep 26, 2012 | 04:04 AM
Welwynnick's Avatar
2006 S600
Were there any warnings for low oil level or low oil pressure?
White smoke usually means a gasket has failed and coolant is being ingested, but burnt oil on the dipstick suggests its game over.
Old Sep 26, 2012 | 12:14 PM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
White smoke usually means the turbo has gone,that's if you got one,,or two.
Old Sep 26, 2012 | 10:04 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
No oil, driving it, turning it off, then still starting it with no oil...OUCH! No warning lamps on the cluster? This is going to be a very expensive repair if there was truly no oil in it. I would be right back at the place who changed the oil. Who did it and in what area by the way? So no one else goes there. Good luck.
Aaron
Old Sep 27, 2012 | 02:25 PM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
Wow, so many things went wrong with your first post that I don't even know where to start. Luckily others chimed in to let you know how awful this is.
Good luck and keep us updated
Old Oct 8, 2012 | 08:11 PM
wsy3benz's Avatar
2004 SL500, 2003 S55, 2002 S430 RIP, 1999 ML430, 1999 SLK Sports 230 Compressor "Sold"
well if its a 2008 hopefully you still have warranty but they may not cover your engine since it sounds like the oil change place. Too bad when you picked up the car there was no warning or error unless you didnt notice. plus it seems like you took your car to a "generic" oil change place I'm assuming?
Good luck and hope it doesnt cost you too much. I guess thats why they are called idiot lights...
