ABS Speed Sensors
Old Jan 27, 2013 | 08:05 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
ABS Speed Sensors
I recently acquired an '04 S55. It took 2 days to drive the car home. On the drive home the SRS light was continually illuminated, the ABS light occasionally lit up, the ABS light showed a couple of times and the cruise control quit working.
After doing a lot of reading it seems like the culprit could be the rear ABS speed sensors. Am I wrong in my diagnosis?
My Indie seems to be focused on "the ignition squib circuit because of the B9223 and B9243 fault codes stored in the ecu.
What do you think?
Old Jan 29, 2013 | 07:42 AM
mrbobby's Avatar
Anyone have these problems before? Thanks Bob
Old Jan 29, 2013 | 08:25 AM
mrbenzes's Avatar
2005 S55, 2002 E430, 2007 CLK350, 2006 SL55, 2003 SL55
NO never heard of rear ABS problems before on an S55...but i have heard of these problems on other models that wad water introduced into the rear Diff...I hope your car has not been in water..that will reak havoc on an S-class as many of the electronics are under the rear seats.
Mike
Old Jan 29, 2013 | 10:33 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
the speed sensors dont go bad that often. your problem is a back wheel bearing that throws the speed sensor off. The speed sensors read from the top race of the wheel bearing.
With Star DAS it will show which sensor is faulty. I have a couple of used speed sensors one if you are interested. I had the same problem and though it was a speed sensor but I was wrong, hence i have the extra ones.
Old Jan 29, 2013 | 03:24 PM
mrbobby's Avatar
I'll certainly keep you in mind if that's where we end up. Thanks Bob
Old Jun 26, 2013 | 10:26 AM
merc79's Avatar
s55 AMG
I've been having this same problem where the ABS,BAS,ESP light come on, but goes away if I turn off the car and restart it again. I did alittle research on the benzworld website and found numerous members saying its the REAR Right Speed Sensor being faulty. Is there a way to diagnose this without using the STAR diagnostic tool? IF it was a bad wheel bearing you would hear it the sound, so its not that I'm pretty sure. Unless the Wheel Speed sensor wiring isn't making proper contact, just have to open it up
Can someone explain or show where the REAr Right Speed Sensor is located precisely??
Thanks.
Old Feb 18, 2014 | 05:52 AM
jflow75's Avatar
2004 s500
my abs light asr and tight steering was all corrected by replacing rear abs speed sensor, the part was 150 dollars at mb.
Old Feb 18, 2014 | 09:55 AM
mrbobby's Avatar
What do you mean by "tight steering"?
Old Feb 18, 2014 | 12:09 PM
merc79's Avatar
s55 AMG
With the ABS and ESP lights on I don't have tight steering, the culprit of my problem is the ESP ,ABS module up in the fuse box, have to replace that out to solve my light problem. Funny thing is my Cruise control works, but traction control off won't work, only stays on full time as default.
