S65 rough when accelerating
Old Aug 31, 2013 | 08:50 PM
w0ss's Avatar
S65
only had it 2 weeks and already a problem
Check engine light came on and when I accelerate it feels very rough. if I just maintain my speed seems ok.
Also saw a spot of oil by the rear drivers side tire.
I am bringing it in on Tuesday to the dealer but wanted to have an idea.
Coil pack and strut?
2006 with 71k miles.
Old Sep 1, 2013 | 04:45 AM
Welwynnick's Avatar
2006 S600
What happens if you stop and re-start the engine? Does the rough running go away?
Nick
Old Sep 1, 2013 | 11:52 AM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
Have you brought it anywhere to read the code? I've had similar problems in an E55 and it was the air flow sensor. I personally have no idea what an S65 has
Old Sep 1, 2013 | 12:00 PM
w0ss's Avatar
S65
I have not started it since, I turned around and drove it right home as soon as I saw the problem. I will start it again and see what it does.
I am going to pick up a code reader this afternoon. Will see what it says.
Old Sep 1, 2013 | 02:50 PM
w0ss's Avatar
S65
started it up and it was still rough.
Read the code and it is P0309. Cylinder 9 misfire. It was listed twice, Confirmed and pending. I cleared both codes and it started up and was smooth. I took it out for a 20 minute run and no issues.
The odd part is when the light came on I wasn't pushing it. I was idling along at maybe 10 mph as I pulled out of my driveway.
Old Sep 3, 2013 | 10:24 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
coil pack is going bad
Old Sep 3, 2013 | 02:59 PM
w0ss's Avatar
S65
I see some old posts where people mention the ignition transformer as a possibility for single cylinder misfires. I am thinking I might replace that first. If that isn't it Coil packs but it hasn't done it since so not sure. I did notice this morning a rough idle, I didn't mention it to the dealer when I dropped it off. While I will have to have them fix the ABC leak I noticed I am planning on doing the Ignition transformer/coil packs myself.
Also where is the best place to order these coil packs/ignition transformer? A quick search for the part I found(000-150-02-58-M22) showed only one place selling it. The coil packs seem to have a few manufacturers. Any reason to buy one over the other?
Sorry for all the question's a search showed some sites but perhaps I am missing something on the part numbers.
Old Sep 21, 2013 | 11:34 PM
w0ss's Avatar
S65
An update.
Both coils were replaced as well as the MAP sensor(found cracked rubber when replacing the coils).
The strut was also replaced as that was the source of the ABC leak.
Old Sep 22, 2013 | 07:36 AM
Welwynnick's Avatar
2006 S600
Did you replace them yourself?
Have you solved the problems?
Nick
Old Sep 22, 2013 | 12:12 PM
w0ss's Avatar
S65
I didn't do them myself. I found that I was covered by a 30 day warranty. Took some arguing with the dealer I bought it from(not a MB dealer) but they fixed it.
It did fix the issue.
