ABC over pressure in resevoir
Old Feb 23, 2014 | 03:15 AM
richvegas's Avatar
2016 S65 AMG coupe, 2010 E63, 2015 Z06/z07 m7 vert 735rwhp, 2000 f-350 crewcab w/ 16" kelderman kit
After work I noticed a large puddle of hydraulic fluid on the ground. I got the car home with no warning lights and when I opened the hood I saw hydraulic fluid all around the drivers side. As I was looking around to try and find the cause fluid started violently spewing out of the dipstick handle. As i hurried to clean it up it happened again. First time was easily 20-30 seconds! I haven't had any warning lights at all and haven't worked on anything ABC related in a while. Only thing I noticed on the drive home was it was riding very stiff.
Anyone experience this?
Old Feb 23, 2014 | 09:02 AM
RaceHorse's Avatar
CL65
Could your accumulators be spent? If the nitrogen leaks out they lose their ability to absorb the ABC fluid that is displaced on bumps from compressing the struts. Maybe if the bladders are weak more fluid out of your reservoir is being maintained in the system and its blowing out when it warms up? This could also be responsible for a harsh ride. As you can see I'm not the guy with an exact answer, I'm just trying to help you guess. lol
Old Feb 23, 2014 | 12:15 PM
richvegas's Avatar
Is definitely possible. I did replace the accumulator sphere that is on the passenger side by the steering rack about a month ago. I'm not sure how many others there are. The rough ride does feel like an accumulator sphere issue. I will have to look into where the other ones are and get them checked out.
Old Feb 23, 2014 | 12:53 PM
jnash's Avatar
2017 S63
Try dropping the static reserve level of the ABC fluid in the reservoir to the min level marked on the dip stick.
I have experienced that any more than this in the reservoir will cause a mess and leaks out of the top presumably due to heat expansion of the fluid?
Old Feb 23, 2014 | 02:40 PM
richvegas's Avatar
How many spheres do I have in the system?
Old Feb 23, 2014 | 05:18 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
/\ Don't quote me on it but i think you have one at each corner and one on the pump itself.
Old Feb 24, 2014 | 04:59 PM
richvegas's Avatar
after speaking with my friends at the dealer they were pretty confident that it is the accumulators on the valve blocks front and back. i will confirm when i have time and money to fix
Old Feb 25, 2014 | 01:57 AM
benz_addict's Avatar
V12TT
could be over filled but in one scenario I've seen an ABC pump going bad and this was one of the symptoms.
Old Feb 25, 2014 | 11:29 PM
jnash's Avatar
2017 S63
https://mbworld.org/forums/cl55-amg-...res-steps.html
