Engine oil dipstick for M275
Old Feb 7, 2017 | 11:01 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Has anyone actually found an engine oil dipstick for our 6.0 V12TT engines? If so, care to share a part number or where it was purchased?
Old Feb 7, 2017 | 11:29 PM
ItalianJoe1's Avatar
2003 CL 600
The only part # listed is the workshop dipstick, which isn't a replacement for the cap and is only used to verify the electronic system is working.
Use the diagnostic mode in the cluster to view the level readout. It's quite accurate.
Old Feb 7, 2017 | 11:37 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
OK, I'll guess I'll read up on how to use the digital readout. Not used to having a car without a proper dipstick...
Old Feb 8, 2017 | 08:01 PM
2003 CL 600
It's pretty simple, with the key on but engine off, on main mileage/trip display, press the little "R" button on the side of the cluster 3 times quickly. You should hear a beep, and it should display voltage. This is the workshop menu, and you can scroll through it with your steering wheel buttons as with any other menu. One page will have the current oil level readout in liters or quarts, I don't recall. You can see it while off or running, unlike the standard oil check screen that only works with the engine off.
Old Feb 8, 2017 | 08:33 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Awesome. Many thanks for that!
Old Feb 14, 2017 | 02:25 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
OK, I'm looking at the service screen and it says OIL LEVEL: --.- QTS.
I don't see a reading. This was done right after shutting the engine off.
Old Feb 14, 2017 | 02:31 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Additionally, when trying to check oil level the regular way, the screen says PERF. SERV. ON TIME.
Edit: never mind. Had to wait about 10 minutes for stopping the engine to get a reading. However, trying to read the oil level from the service screen only shows --.- QTS until the engine is started, and then I saw a value go from ~9 qts down to 6.2 which I thought was strange. Why doesn't it give me a reading with the engine off?
Old Feb 15, 2017 | 06:18 PM
2003 CL 600
With the key on and engine off it gives no reading? That is odd, my car doesn't do that, it shows the reading with the engine running or not. Key must be on though.
Old Feb 15, 2017 | 09:38 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Yes, key set to ON position. Next position would have started the engine. Within the service menu, the oil read out just shows --.- QTS until the engine is started.
Maybe this functionality is a bit different for the S65?
Old Feb 15, 2017 | 10:57 PM
2003 CL 600
Some things are different on my car since it's a 2003 as well. I'll try to confirm on another vehicle when I can.
Old Feb 18, 2017 | 02:42 PM
pumpgas's Avatar
2007 S65 AMG
I use the same dipstick I use to check the transmission fluid one level is for cold and the other when the trans is warm.
For the oil level, right after an oil & filter change with the 10.5 qts. (I always put in 11) and measuring the level the following day when the car has sat overnight after driving, the oil should be right at the black mark I have on the metal portion. Almost 5 inches from the plastic tip.
Readings for both levels are 100% accurate. Tom
Bought it off Amazon. $25
Mercedes Benz 722.6 Automatic Transmission Fluid Dipstick 1220mm 140589152100
Attached Thumbnails Engine oil dipstick for M275-20170218_142815.jpg   Engine oil dipstick for M275-20170218_142636.jpg   Engine oil dipstick for M275-20170218_142542.jpg
Old Feb 18, 2017 | 05:25 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Thanks Tom, that's fantastic. I'll order one of those dipsticks.
Old Feb 19, 2017 | 10:00 AM
pumpgas's Avatar
2007 S65 AMG
Anytime James!
Old Mar 15, 2017 | 12:21 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Quick question about the dipstick described above. Since our cars have the 722.6 5-speed transmission, when the gearbox is hot, should the fluid level be between the 80* hash marks and when cold, between the 25* marks?
Old Mar 15, 2017 | 01:26 PM
pumpgas's Avatar
2007 S65 AMG
Yes when warm it should be within the 80 marks. To measure the transmission fluid though, you have to make sure you get the dipstick all the way to the bottom of the transmission pan by wiggling it some. It will feel like it stops initially but then when you move it a little it will drop in about another 3 inches or so. Watched the service manager at the dealership do it once so I knew how far it needed to go in.
I would say there is about a foot or so of the dipstick that still sticks out even when measuring the trans fluid.
Even more of it when measuring the oil.
Old Mar 15, 2017 | 01:28 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Thanks for clarifying. Much appreciated!
