03' S55
Old Mar 6, 2017 | 09:04 PM
WillyG's Avatar
S55 Designo
03' S55
Hey quick question, I have a smaller supercharger pulley and Ecu tune. I am planning on doing headers next. When would I need to upgrade to a bigger Heat Exchanger?
Old Mar 7, 2017 | 02:09 AM
E42AMG???'s Avatar
E420
Well "need too" I guess you could say not for those mods considering the s55 has an extra heat exchanger compared to the e55 and when people mod they put another one on which has similar cooling capabilities to the s55 stock system.
You can add another h/e, the longer you can keep the iat down the longer the power will stay.
There is lots of ways to mod the cooling system.
split it from the engines coolant
add a trunk tank
higher flowing pump
what headers are you getting?
Old Mar 7, 2017 | 12:28 PM
WillyG's Avatar
S55 Designo
add a trunk tank
higher flowing pump
I have an 010 Bosch in the box still, is bleeding the system necessary or will it bleed itself? I think I'm just gonna go with kleemanns mid lengths. Was gonna try EC w211 mid lengths but someone else attempted on a cl55 and it was not gonna happen. Maybe even do the 82mm throttle body down the road.
Old Mar 7, 2017 | 02:30 PM
cmpcpro's Avatar
2004 CLK 500
If your just replacing the pump and on an S you don't need to bleed it. The cap that you use to bleed it on the E has a hose going to the coolant tank on the S.
Old Mar 7, 2017 | 06:15 PM
E42AMG???'s Avatar
E420
No bleeding neccasary
Old Mar 7, 2017 | 11:38 PM
WillyG's Avatar
S55 Designo
Any experience with kleemann mid lengths?
Old Sep 14, 2020 | 09:41 PM
MartinWake's Avatar
CL55
They say they are bad but are the only ones that fit CL and S class cars
Old Oct 29, 2020 | 01:32 AM
Shax Shux's Avatar
2003 S55 Kompressor
Hey, so do you think upgrading a HE is unnecessary since it already has two? I want to go with a smaller pulley, I have Eurocharged tune and Bosch 010 pump put on already. Thanks
Old Oct 30, 2020 | 12:50 AM
E42AMG???'s Avatar
E420
only if you are doing back to back pulls,
wouldnt waste your money
Old Oct 30, 2020 | 01:00 AM
Shax Shux's Avatar
2003 S55 Kompressor
Other than pulley, what other components do you have to replace? And what size of pulley are you recommend? Thanks
Old Oct 30, 2020 | 01:52 AM
E42AMG???'s Avatar
E420
74mm is the smallest, unless you plan on doing long tube headers in the future
