Billet/Poly engine mounts for S65 and S600 M275
Old May 23, 2019 | 10:24 AM
East Coast Euro's Avatar
Former Vendor of MBWorld
C63 and CLK55
We are pleased to announce our V12 biturbo M275 mounts are in stock and ready for sale! The engine mounts are fully serviceable and can be rebuilt if ever needed by just refilling the polyurethane inserts. The M275 is well known for ripping engine mounts due to the high torque the engines produce. Our mounts reduce engine movement providing better throttle response. The mounts are made and assembled in the USA and come with a black anodized finish. Intro pricing is $465 shipped in the USA.
Old May 29, 2019 | 07:56 PM
Simon Ray's Avatar
CL600, Transit Connect
This looks to be a gret idea.
How do your mounts compare to stock for isolation/NVH?
How long can the mounts go before a rebuild is needed?
What is the price for the components that would be needed for a rebuild?
Old May 29, 2019 | 08:06 PM
C63 and CLK55
Thank you. These mounts are much stronger and stiffer providing better throttle response. Because the V12 is so smooth there is almost no NVH. There are too many variables to guess as to how long they will need before a rebuild to be honest. A refill of polyurethane is $60. Let me know if you have any other questions.
Old May 30, 2019 | 02:31 PM
JohnLane's Avatar
222 S-65
LOL.... Figures! I replaced the engine mounts in my S-65 two days ago.
Guys how many hours of labor has the dealership quoted to replace mounts for your bent 12? I recall 12 hours. I did them in two hours.
Old Mar 21, 2020 | 07:00 PM
osmanovich's Avatar
S 600 w221
Can you describe your job in detail or post some pictures about it
Old Mar 22, 2020 | 12:05 PM
JohnLane's Avatar
222 S-65
I didn't take any photos. Here's the reader's digest version....
First up.... This happens on a hoist. Get a case of brakeclean as you will use it to clean things up.
Airtools and a strong assistant are required.
Pull all three pieces of plastic under engine and trans. Makes a big handful of those screws with the nice fat washers that have an 8mm head on them. This is your opportunity to replace all the female guys the screws mate up with as there are a number of them that are junk by now. MB stocks them and the screws.
A screwjack with a 2X4 cut to an appropriate length will make it easy to spread out the load of picking up the engine.
Unplug the electrical connector at the steering rack. Follow the steering shaft from inside the car to the rack to find it.
A Sharpie pen will mark the steering shaft for where it belongs. One 13mm head bolt gets removed and the steering shaft slides up and out of the way. Four fasteners hold the steering rack in place. The steering rack does not get removed. Support the steering rack. Pull them fasteners. Now you have access to bolts on top of engine mounts. Pull them. Bit of a treat to do. Seems like I may have got to the driver's side bolt on top of the mount from above with a long extension and a wobbly. Others feel free to chime in. Pull fasteners on bottom of engine mounts. Engine mounts are now free agents. But they don't just jump out of there.
There are (if failing memory serves) a couple of PITA little fasteners that connect the ABC line from valve body to R/F wheel on the subframe. Pull them. Be sure the line can move around.
Support the engine with screw jack. Pull fasteners for front subframe. It is connected to all the suspension parts so it won't just fall out.
Your engine is on a screw jack. Don't screw up! Raise the engine while wrestling the subframe down with a pry bar. Be gentle and choose what you pry against carefully. Make enough room for driver's side mount to come out the rear. It is the easier of the two. Passenger side requires a certain amount of colorful adjectives.
You'd think that the new mounts would just jump back in there but nooooo.... You are replacing dead mounts that are shorter then the new mounts. Be patient... They go in.
Assembly is opposite of disassembly. A second screw jack is required to lift the subframe back into place.
Take your time.
Wow I hate the bulletin board software that 'edits' my spelling, adds words or moves the cursor a paragraph up!
Old Mar 22, 2020 | 02:22 PM
osmanovich's Avatar
S 600 w221
wow when you describing it like that it sounds very easy, but it is a big job that requires a lot of space around
thank you for detailed description I really appreciate it
Old Dec 15, 2022 | 02:58 PM
David7390's Avatar
s55 amg 2004
M275 engine and trans mount
Where can I buy you engine mounts and do you have trans mounts?
Old May 28, 2023 | 09:24 PM
Tykitchens1's Avatar
2007 s600
I NEED A LINK TO THIS!! IS IT STILL AVAILABLE?
Old May 29, 2023 | 11:16 PM
JohnLane's Avatar
222 S-65
I’m curious to know if the same mounts are used in 279 powered 222 Chassis S-65.
Old May 24, 2024 | 08:17 PM
mrvedit's Avatar
2004 SL600
And another bump - are they still available and would they fit an SL600?
