Shaking when accelerating
It does lug the engine at low rpms with light throttle, because it's more efficient and helps gas mileage. But you can easily override that with sport mode, or slightly more throttle.
Hope this helps.
Bill
I haven’t measured acceleration differences, will do so when my BlackBoost intake arrives and is installed.
Are you modded or bone stock? I started having these issues only after ECU tune.
The Weistec TCU tune results in faster and more firm shifts. This is accomplished with faster target shift times and running higher line pressure which also has the added benefit of reducing slip and increasing the torque capacity of the transmission. With higher line pressure, the clutches in the transmission are clamped harder making for better grip which directly allows the transmission to hold more torque. With less slip and faster shifts, the lifespan of the transmission is typically improved as well.Key Features
- Faster Shifts
- Firmer Shifts
- Increased Line Pressure
- Increased Torque Capacity
- Faster Shifts
- Firmer Shifts
Funny thing is, my CarFax said the plugs had been changed at 42kmi, but looking at them with now 60kmi I don't think they were. Change your plugs, it just can't hurt.
O2 = I had a 2003 G35, when I replaced all 4 O2 sensors one was completely broken off, it NEVER threw a code. O2 sensors can also get slow over time and not throw a code so I change mine every 60 - 70kmi.
