Air Balance Retrofit for GT43/GT53/GT63 x290
In case anyone's been through the process before, hoping for insight in the following areas.
- Is this something the dealer might offer even if it didn't come w/the car?
- Looking for a good resource for which parts I'd need to switch out?
- Saw a similar post here about the w213, but nothing on the x290.
https://mercteil.com/air-balance-pac...retrofit-r1x83
Will be taking this one next month or so, may post install notes and more on using DTS for this in case anyone is interested.
https://www.mercedesbenz.parts/v-201...rfume-atomizer
Air Balance Parts:
- Mounting Plate Bolts: A001984572964
- Hose Assembly Bracket: A0029957277
- Air Duct: A2138303501
- Air Duct: A2138313000
- Fragrance System Mounting Plate: A2228900087
- Fragrance System Housing: 2228900100
- Fragrance System Ionization Control Module: A2238351600
- Fragrance System Hose Assembly: A2538000000
Will post back after the install and verify if everything went well.
Thanks for putting out that pdf vvery nice of you to do all that.
