Alignment Specs & Tire wear
Old Apr 9, 2025 | 07:55 AM
Dicecal's Avatar
2023 AMG GT 63 S, 2020 F8 Tributo, 2024 992 TTS
So corded the front tire inside shoulders with just around 9000 miles on the car. New tires and alignment attempted and I was told by the shop the front alignment is set at - 2.5 degrees of camber and is NOT adjustable? I was kinda shocked to hear this, as I was wanting to take some of the negative camber out as obviously this is a street driven car. Anyone know what the factory OEM alignment specs are for a 2023 AMG GT 63 S, big wheel set and carbon ceramic brakes if that makes a difference. Is it true there is no way to adjust camber on the car- still find that shocking. Thanks in advance.
Old Apr 11, 2025 | 06:49 AM
Dicecal's Avatar
Car is currently at the dealership for a B service and they are checking the alignment, seems like there is little to NO adjustability for camber. When I get the car back hopefully I’ll have more info and exactly what the OEM specs are.
Old Apr 11, 2025 | 08:29 AM
Freder8d's Avatar
2017 AMG C43
This is normal they said.
Old Apr 11, 2025 | 08:53 AM
ygmn's Avatar
2015 E400 Sedan
Yes it is NORMAL
but does not make it CORRECT.
It is normal because they have o way to adjust CAMBER to preven this from happening.
I mean what is more important to the average driver?
SUPER DUPER track performance around a curve for couple hundred mile race
OR
The average driver gets blowouts, flat tires every 5-50K miles or a DEFLATED or FLAT wallet of cash since they are buying tires so much.
ever try to see th inside tread on these sedans? I cannot too dayum far under and low to ground...so I try checking them with my cellphone pictures... does not helpmuch
Point is you need to get your tires checked way more often then the oil change interval..
too me this is a safety issue as it would suck to have a blow in doing 70mph on interstate because cmaber is off, non-adjustable, "NORMAL" but only 5000 miles into your 50,000 mile treadlife tires.
Old grandma gonna end up in the guardrail....
Old Apr 11, 2025 | 01:52 PM
Dicecal's Avatar
Unfortunately true for these cars…
Old Apr 11, 2025 | 03:21 PM
superswiss's Avatar
2019 C63CS
Yes, that's normal on at least the 63 AMG models. Camber in the front is aggressive and as said can't be adjusted without aftermarket adjustable control arms. Rear camber I believe can be adjusted with shims on some models at least. The GT 2-door has adjustable camber on all four corners, at least the GT R and up and comes with a set of shims from the factory so you can align it for specific tracks, but the more street focused AMGs have fixed camber. That's the nature of the beast. It's a performance car. If you mostly drive it like a Toyota Camry, then maybe a Toyota Camry is a more suitable car. These are designed to be driven at triple digit speeds on the German Autobahn every day, not in 25 mph commuter grid lock. There are better suited cars for that. Either get a more normal commuter car, or be willing to deal with the consequences of daily driving a performance car in commuter traffic etc.
These cars are not designed to maximize tire life. Tires are consumables, so are brakes. You gonna end up replacing both of these frequently with a car like this. Especially as heavy as the GT 4-door is. Wrong car if you are expecting to get 30k miles from your tires. FWIW, in the rear I get fairly close to the tread wear warranty of 15k miles that Michelin provides for staggered non rotatable setups with my C63S coupe, and around 8k for the fronts. I could file a warranty claim for the fronts, but it just hasn't been worth it to me. I knew what I was getting into with a car like this, and I don't daily drive anyway.
Old Apr 11, 2025 | 05:23 PM
Dicecal's Avatar
Regardless it would be nice to have some adjustability. My 992 Turbo S OEM spec front is -0.9 - 0.5, and pushed that out to -1.5 which is a nice compromise and a lot easier on the tires. IMHO anything close or exceeding -2.0 unnecessarily wears tires for normal road use.
Old Apr 11, 2025 | 07:47 PM
superswiss's Avatar
2019 C63CS
Different car a 911. Lighter front with less weight transfer during cornering, so less static negative camber is required to maintain optimal contact patch during cornering. At least that's the theory. More weight in the front pushes down on the outer wheel more in corners, you so you need to start with more static camber in order to have optimal dynamic camber while cornering.
Old Apr 11, 2025 | 07:51 PM
Dicecal's Avatar
Well the take away is you can change the camber settings on most cars to suit your driving needs/style, would have liked to have that option on this car.
Old Apr 11, 2025 | 07:57 PM
superswiss's Avatar
2019 C63CS
Actually, the trend is towards non adjustable camber and caster. For me no, I have no desire to reduce camber. As I said, I didn't buy my car to commute and doodle around in the daily mess. I hit up the canyons and fun roads with it, so lots of cornering. If I had a commute, I'd have a commuter car for that.
Old Apr 11, 2025 | 07:58 PM
Dicecal's Avatar
As always YMMV, I have other cars for that.
Old Apr 11, 2025 | 08:00 PM
superswiss's Avatar
2019 C63CS
Use the right tool for the job as they say.
Old Apr 13, 2025 | 07:04 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Yes but both AMG and AMG GT are “PERFORMANCE MODELS” Yet - basic Front Camber and Caster along with rear Camber has been deleted. No longer can you simply dial in Front and Rear Camber to suit your driving conditions !
All to do with cost cutting and ever increasing speed of new car assembly lines. Stopping assembly to precisely adjust is no longer an option.
Yet Camber is essential - allowing to “adjust tire contact angles” for spirited driving or Track days. Being able to dramatically reduce understeer - allowing to go deeper into the corners with increased traction and braking response. Or lowering and subsequent wheel squat and premature inner edge wear.
Instead onus is now put back on owners to fund costly, premature tire replacement !
Only on AMG GT Coupe models - the way around it you can purchase front and rear shim kits - but labour and time consuming to install / adjust each time.
K-MAC has the experience of resolving OEM Suspension shortcomings since 1964 !
Including manufacturing BOLT-ON front and rear adjustable kits for virtually every model Mercedes Benz 1968 to 2025.
Including AMG GT 4 door - regretfully, currently not for Coupe models but we are working on it !
K-MAC kits are specially designed so no special tools required or time consuming need to remove control arms to install.
Unlike shim kits unique patented design allows fast easily accessible precise single wrench adjustment. Ultimate - direct on alignment rack UNDER LOAD.
SEE SPOILER
Spoiler
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings (and Costs) Since 1964 !
