Post your wheel/tire setup with pictures and information...
Why not make a thread of all of our setups. Post pictures of wheel size , offset , tire size and if any fender mods were needed to make that setup work. This would be a good reference thread for newcomers or just members looking to switch it up, this way you can get an idea of what size/setup you would like to run before making any big purchases.
This is for any w212 e63 model.
List the following. Summer & Winter wheels , OEM or Aftermarket.
Wheel make/name (ADV1)
Wheel size (20x9.0)
Offset (33-45ET)
Tire size (285/40/20)
Suspension (coilovers/h&r sports/stock...etc etc)
Modifications if needed (fender roll/trimmed fender liners/spacers...etc etc)
And most of all post 2-4 good images of each setup so that the fitment can be seen clearly.
Please try to keep the images semi small (800x600ish) so that there is better load time. thanks.
Wheel size (20x9.0)
Offset (33-45ET)
The following 2 users liked this post by wolves.creed:
2012 CCB E63 (12-29-2016),
mj_39 (12-29-2016)
I'll bite even though I am on OEMs.
Wheel --- OEM
Wheel sizes --- F: 19x9 R: 19x9.5
Offset --- F: +37 R: +52
Spacers --- F: 10mm R: 13mm
Suspension --- H&R springs and rear endlinks.
Fender mods --- None.
* Note. I do rub. Turning the wheel at low speeds and going over dips at high speed. I will work on correcting this hopefully with an aftermarket set.
Pics:
Wheel --- OEM
Pics:
The following 2 users liked this post by CarHopper:
E63_SauceGod (05-17-2019),
Ed99 (01-20-2017)
CarHopper (12-30-2016)
Wheel --- OEM
Wheel --- OEM
The following 3 users liked this post by sjb:
Avant Garde F411
19x9 30ET 19x10.5 50ET
265/30/19 305/30/19
No spacers
Stock height (trying to talk myself into sacrificing ride quality)
Here are some horrible quick pics. I'll replace these with decent ones when I get the tires cleaned up from the install.
265/30/19 305/30/19
No spacers
delete.
I think I could still lower this car and not rub. After the camber is reset I might have to adjust the offset slightly to but I think it can be done. 295s would be no problem and if you're not lowered I think (but don't hold me to it) ET45 would work.
2014 Mercedes E63S AMG
Here is my setup.
Rohana RF2 wheels on Nitto Neo Gen All-Season Tires, factory height, no rubbing on any suspension settings ever. Tires are within .1" overall diameter of factory 19" tires. If I put a straightedge (yard stick) on the fender lip to the ground down the center of the wheel, the face of the outer lip of the rim is 7mm in from the fender on the front and rear both so these are the correct offsets to be even. I would like to lower the front 1/2" if I can find springs that do that, I dont forsee any reason it would rub then either.
Front:
20x9, 25mm offset Wheel
245/30ZR20 Tire
Rear:
20x10, 45mm offset Wheel
305/25ZR20 Tire
Front:
245/30ZR20 Tire
Rear:
305/25ZR20 Tire
iownedu, that thing looks nasty. I am usually not a fan of colored wheels, but wow. The red really sets off and compliments the whole car. If only it had that color red interior!!! I've considered red Vossen's, but I feel like that is the BBS of the tuner world. Great looking wheels, but everyone has them. These are unique!
My car actually has designo Mystic red/black interior as well.
No proper pics yet. Waiting for summer to do that now. But here's what I am running in the summer...
Wheel make/name: Vossen VLE1
Wheel size: FR-20x9.0 R-20x10.5
Offset: FR-32 R-42
Tire size: FR:255-30-20 R-285-25-20
Suspension: Stock for now but have springs and links to be put on soon.
Offset: FR-32 R-42
Ed99 (01-06-2019)
Wow, that's a unique look for the wagon! Very nice.
Offset: FR-32 R-42
Offset: FR-32 R-42
E63s
Here is my setup.
Front:
245/30ZR20 Tire
Rear:
305/25ZR20 Tire
Front:
245/30ZR20 Tire
Rear:
305/25ZR20 Tire
^ looks great! Rear fitment looks perfect. Are you rubbing at all? What are you lowered on? Which brand tires are you running? Lastly, how's the fitment front vs rear?
