Brake cooling ducts and modified front bumper
When I widened my rear fenders, I was able to move up to a 295/30-19 PSC2 on my Vorsteiner VSC101 19x10" ET52 rears. No problem.
At the same time, I went up one size in front to a 255/35-19 PSC2 on the 19x8.5" ET45 fronts. They run wide, and I'm starting to wonder if that might be too much tire. I had mistakenly thought I was working with a 9" wide wheel duh. I think I'm barely outside what's considered 'acceptable' with just over 10" section width on the 8.5" rim.
What do you think? Keep in mind the abuse I intend to create for them on track. Thanks.
Here's what Michelin (Tire Rack) says:
Sorry for the late reply... just got back from four days of sliding and drifting in various AMGs on ice (w/ custom studded racing tires of course) at Gimli. Few teaser pics below.
For track duty, a PSC2 255/35 is probably too wide on an 8.5" rim, especially on a heavy car like the 63. You'll be rolling over the outer sidewall while the inner one would be folding under the rim. Aside from handling issues, at worst you could pop the outer bead or get a blowout on the inner sidewall where the carcass will fold under. If you were using "greasier" tires, for street driving and on a lighter car you'd be fine, but IMHO you're looking for trouble with this setup. Rule of thumb for track use is that you always go with the widest approved rim size for a particular tire - so for those PSC2s, you'd ideally want 10" wide rims.
Gimli looks like a BLAST! What cars did you get to drive?
Based on the amount of "Cant believe we didnt do it" whining, we will be going next year for sure lol.
Now I'm nervous about my 295's on the 10" rear too.
Ugh, this sounds like it's going to be expensive.
Re Gimli - we had 6 CLS63Ss, 6 C63Ss and 6 CLA45s. The Cs and CLAs were a blast. The CLSs were great for stupidly massive drifts at 140 km/h at an 80 degree drift angle on a huge (~700 m) circle, but they have the momentum of a medium-sized planet. Trying to get them to change direction on one of the tighter tracks is... well, frustrating. Unless you get the speed and drift angle just right everywhere, there's no correcting and you end up in the snow bank. Great learning tools though - they force you to be smooth instead of aggressive (which you could do to an extent in the other two). And, Gimli beats Sweden hands-down for a number of reasons - so much so that next year they're changing the format and track in Sweden to what the Canadian AMG DA was doing at Gimli. Plus, I hear that now Porsche and Lamborghini are coming to Gimli next year as well for thier winter programs.
Weistec TCU and Trans Pan: https://mbworld.org/forums/c63-amg-w...ml#post6777815
44O Cooling Kit:
Brake Cooling and Front Bumper Mod: (this thread)
RacingBrake BBK: https://mbworld.org/forums/c63-amg-w...their-car.html
Track Tires and Rear Fender Widening: https://mbworld.org/forums/c63-amg-w...ack-tires.html
UltraRacing Underbody Braces:
KW Clubsports and Full KMAC Bushing Kit: (starting below)
DIY Swaybar End Links: https://mbworld.org/forums/c63-amg-w...ncy-power.html
Spoon Rigid Collars: https://mbworld.org/forums/c63-amg-w...ollar-c63.html
Alcantara Dash and Red Seatbelts: https://mbworld.org/forums/c63-amg-w...Alcantara+dash
DIY Morimoto HIDs: [TBD]
Weistec Billet Idler Pulleys: [TBD]
So, here's what needs to go on before Apr 23.
KW Clubsports (thanks to Golan at AutoTalent)
KMAC Full Bushing Set - front and rear adjustable camber bushings and rear suspension set (Kevin was great about getting these out to me asap)
Spoon Rigid Collars and Sparco Tow Straps
The right sized end link bolts and QA1 high misalignment spacers came in. Thanks for the solid 7" rod JD, just got it today.
You can really see the difference versus the non-adjustable units that came with the KWs for the front swaybar. The only questionable thing now, is that on its shortest setting, the DIY 7" end link is the exact length of the unit KW sent for the front. This means that I should probably have used 1" shorter rod in front at least. I won't know until I try to fit, but I'm thinking that 6" front and 7" back is about right for the Joes aluminum rod length. I didn't take into account how much beefier the QA1 rod ends were, and that makes a difference in total bolt-to-bolt length and adjustment. Just something to keep in mind. I might order an extra pair of 6" rods just in case I run into issues on the install.
That's it for now. Going to try to finish taking apart the dash this afternoon for the other other project. They are stacking up.
Having an 11yo boy and a 14yo girl has just about ground me to a halt on this kind of thing. Now its a big deal that I am going to change my rims and emblems, and cant even be bothered to re-install my illuminated sills lol.
