Old Jun 26, 2017 | 06:16 PM
  #376
sterz85's Avatar
w205 C43, 958.1 CTT
what are your plans for the sound/media (bluetooth/telephone) system
are you going to keep the original one that came with the car, or do you have something planned to update it? any idea if the russian company you used for the steering wheel and window switches can integrate the MOST command system with the updated telephone/bluetooth into the D2B system the earlier w463s have?
Old Jun 27, 2017 | 03:37 AM
  #377
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
I might use command unit from face-lifted Mercedes W203.
BUT I have been looking at the Chinese Android based units. They look similar to the original Mercedes units but have all the newer tech features...
As for the company in Russia. Im sure they can do anything but not sure if they would need your vehicle to be in the shop for that.
Your more then welcome to email them dolcar@bk.ru or msg them on Instagram. They usually get back in a day or so.
Old Jun 27, 2017 | 03:45 AM
  #378
Today I purchased sound deadening material from "Silent Coat" in Las Vegas. Roy was very helpfull and gave me an amazing deal. I purchased 140 sq/ft of the product and can't wait to start installing it all over the car. Product should be here later this week, will post picture when it arrives.
Here is a photo of what it looks like...
Old Jun 27, 2017 | 02:33 PM
  #379
Received some custom floor mats from Germany. For cargo area also. Look nice and good quality.
Old Jun 28, 2017 | 11:00 PM
  #380
Replaced stepper motor lever. When the dash is completely off it only takes one minute to do ))
Old Jun 28, 2017 | 11:03 PM
  #381
Pulled it out into the sunlight to work on the stepper lever.
Old Jun 29, 2017 | 11:54 PM
  #382
While the fenders and hood are still off the vehicle I decided to take care of the leaking valve cover gasket.
Old Jun 30, 2017 | 09:17 AM
  #383
illest's Avatar
w210 AMG or S213
plan to paint the valve covers?
Old Jun 30, 2017 | 10:30 AM
  #384
I did want to do that at first, but I might swap out the engine for AMG 55 at some point (in the future) so now I'm not going to paint it. I'll just leave it as-is.
Old Jun 30, 2017 | 10:18 PM
  #385
Finished replacing valve cover gasket's.
All new breather hoses.
Cleaned MAF sensor.
Replaced all the spark plugs.
New fuel filter (messy job, got gasoline "all over" myself)
New air filters.
Old Jun 30, 2017 | 10:25 PM
  #386
First 3 boxes of "Silent Coat" sound deadening arrived.
5 more boxes on their way.
2mm on doors
4mm on floor, firewall & roof.
Old Jul 1, 2017 | 03:41 PM
  #387
Old Jul 1, 2017 | 03:42 PM
  #388
Fuel filter
Old Jul 1, 2017 | 03:44 PM
  #389
Applied two sheets of the sound deadning on to the front door. It's going to get covered with a layer of "closed cell sound deadening foam" as well, but it's looking good 👍
Old Jul 5, 2017 | 03:13 AM
  #390
Removed center shaft between transfer case and transmission. Boot was torn, looked pretty nasty inside. Purchased boot kit for both ends.
New center shaft bolts and nuts.
Replacing transmission mount and transfer case mounts.
Old Jul 5, 2017 | 05:16 AM
  #391
ponyboy3's Avatar
2002 G500
random wires
hi, first off, this might be the best build ive ever seen! and i love watching build threads.
sorry im using your picture, but its exactly what i need...
i bought my g500 with missing ecu and the fuse/relay block, items in blue
I have since installed the items, but i have three bundles that I do not know where to connect. You have two of them pictured, hopefully you can tell me. both are circled in pink.
the first one is taped to the control unit on the floor, does that say door sill? if not where does it connect to?
the second is the blue bundle, where does that go?
Old Jul 5, 2017 | 11:31 AM
  #392
Hello
thank you.
yes, the one on the bottom is for the door sills.
ill check where / if the other one is plugged in.
I have noticed that some wires are just not plugged in in some cases due to them having no function...
Old Jul 6, 2017 | 11:02 PM
  #393
While I'm waiting for the center shaft boot kit and transfer case mounts to arrive, I install sound deadning on driver side front and rear door. When knocking on the doors with your knuckles, difference is night and day. Without any sound deadening it sounds like an empty can. With it, it sounds "dead"... zero noise vibration in the sheet-metal.
I definitely recommend this product and this process if someone wants to make their car quieter ������
www.silentcoat.us
Old Jul 8, 2017 | 11:44 PM
  #394
More sound deadening
Old Jul 10, 2017 | 12:34 AM
  #395
PONYBOY
I looked at that blue wire and I think it was never connected.... It might be one of those wires.
**If someone else can chime in and tell us what is the function of this wire, it would be helpful.
Old Jul 11, 2017 | 07:06 PM
  #396
My steering wheel and front door window switches arrived back from Russia. Steering wheel has been modified to work with 2002 G500, it's now plug-and-play. (they also included a spacer between the steering column and the steering wheel cover up a gap).
Window switch internals have been reworked to operate with my original wiring. They tested these parts on a vehicle they had in the shop and everything is functional 👍
Now we wait for reassembly...
I'm working on another modification with them which I will disclose once they confirm that its doable.
Old Jul 12, 2017 | 01:17 AM
  #397
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Very cool. Will the power fold mirror function work? If so, what rewiring had to be done. Also, what about the paddle shifters on the wheel?
Old Jul 12, 2017 | 01:23 AM
  #398
Thank you
Yes, mirror folding function will work, thats what the orange wire was pulled out for.
I do not know what they did, but they told me they had to rewire the internal and install resistors due to different voltage flow.
Paddles will not work. Something I did not want to deal with... Maybe if I was there with the car or if they were here I would have them work on it.
These guys did amazing work, if anyone wants them to do some work, check them out on Instagram: https://www.instagram.com/dol.car/
Old Jul 12, 2017 | 02:54 PM
  #399
gurukid's Avatar
W463 G500, W463 G55, W222 S550, F10 M5, RR VOGUE, R107 560SL, VANTAGE, F430, 911
Originally Posted by Kobzarhomes
Thank you
I'm about to send out my switches as well. Might just ask them if I can purchase the diagrams and solder it myself instead - no wait, no shipping.
In regards to the paddles, if you want to do it, I can help you. I've done it on a bunch of different cars from BMW to Land Rover. I just recently did it on my RR fullsize. Although, I wouldn't really advise doing it on the G wagon, it doesn't seem worthwhile, the shifting in general is slow anyways and a little clunky, paddles would only be a nuisance.
Either way, if you want to do it, let me know, it's relatively easy and straightforward. I'll be doing it to my G when my stuff gets to Russia than comes back, if they dont want to sell me the diagrams.
What shipping company did you use? I plan on using FedEx IP or DHL.
Thanks,
Old Jul 12, 2017 | 03:02 PM
  #400
Yeah I don't think it's worth messing with the paddles and getting them to work on this car... if I change my mind I'll definitely let you know .
I used the cheapest route they had available which I wouldn't recommend because it took a month and a week to get the parts there. I think DHL is a good company to ship because that's what they use to ship the parts back. I think it's still gonna take approximately about a month for the parts to arrive to them but when they ship them back to me I got it within a week.
I would confirm and double confirm the address and make sure it's clearly written on the shipping package when you ship it to Russia just so they don't have any confusion delivering it .
