Old Jul 28, 2017 | 10:07 PM
  #426
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
Would it be cost prohibited to add portal axles that the 4x4^2 has?
Old Jul 28, 2017 | 10:11 PM
  #427
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
It's doable but they do cost around $20,000 just for the portal axles, not including other parts that are needed and labor.
Old Jul 28, 2017 | 10:12 PM
  #428
Chedman13's Avatar
Wow, a lift kit is more economical if you don't need the actual clearance. Thanks, didn't know it was that much.
Old Jul 29, 2017 | 11:28 PM
  #429
Sound deadening on trunk floor completed
Old Jul 31, 2017 | 10:07 AM
  #430
bjonesG500's Avatar
2004 G500
Gwagon restoration headliner pictures
I really like that you are taken your time and addressing every part of your G wagon as you should! Great Job!
Didn't you also changed your sunroof to a moon roof! Did you get the moon roof insert from a dealer? I just got hood winked by an upholster that gave my G back to me without installing the sunroof panels with suede material I provided! I was like really! The 95% looks great but You know this isn't going to go well for me! I was so blown!
Now I have to have someone else complete this part of the job! He is telling me that another upholster says it can be replaced without removing the headliner!
Can you remove the sunroof inserts without taking the headliner out?
I also installed the after market mirrors and both motors burned out! drivers side in the closed position! You mentioned the wiring was changed I think because of voltage differences! I do see that there are new motors on ebay but don't have a place to send them for repair. Was your place in the US?
Thanks for your responses also! I look everyday to see if you posted any more pictures of the wonderful recreation!
Brad
Old Jul 31, 2017 | 08:05 PM
  #431
Finished installing center shaft. Torqued bolts/nuts to 60nM.
Old Jul 31, 2017 | 09:09 PM
  #432
Hi Brad
Thank you
I installed the moon roof myself. It did require some modifications, wasn't very easy, but I got it done. I posted some pictures of how I was installing it earlier in my thread.
If you still have the steel sunroof you can remove and install the interior panel without removing the headliner. You would install it from the outside of the car, from the top and then it should just clip in with couple or few clips.
I have not had a chance to connect my door mirrors, but I hear that the turn signals in the mirrors do throw an error message so they might require a resistor. The guys that rewired my window switch did install a resistor for the mirror folding option on that switch. I don't know exactly what they did. They are located in the Russia so I had to send the switch and some other parts out to them.
Old Aug 1, 2017 | 10:47 PM
  #433
Front passenger side floor sound deadening completed
Old Aug 3, 2017 | 09:53 PM
  #434
Sound deadening on the floor is finished.
Now I will add a layer of closed cell foam inside the doors and on the roof.
Old Aug 6, 2017 | 02:03 AM
  #435
Old Aug 8, 2017 | 12:33 AM
  #436
Started clearcoat sanding process.
1200 dry with DA sander
3000 "3M tizact" wet with DA sander
Old Aug 10, 2017 | 10:49 PM
  #437
Rear end and right side polished 👍
Old Aug 10, 2017 | 10:50 PM
  #438
New door checks
Old Aug 12, 2017 | 10:33 PM
  #439
Finished polishing the body and installed rear glass.
Covered rear end with protective plastic.
Old Aug 12, 2017 | 10:48 PM
  #440
3 stage polish.
Here is what I'm using.
Old Aug 12, 2017 | 10:57 PM
  #441
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
Originally Posted by Kobzarhomes
3 stage polish.
Starting to come together. Great job. Looking forward to further reports.
Old Aug 13, 2017 | 07:01 PM
  #442
sick430's Avatar
CLK Cabrio
Love this thread, you have helped me decided to purchase a 90s diesel and restore it.
Old Aug 13, 2017 | 09:34 PM
  #443
Thank you
These cars are amazing, restoring them is worth it and a joy )
Old Aug 15, 2017 | 10:20 PM
  #444
Added more sound deadening on the doors in a form of 5mm close-cell foam pad.
Installed couple door locks / latches.
Old Aug 16, 2017 | 12:08 AM
  #445
sterz85's Avatar
w205 C43, 958.1 CTT
Have you thought about adding a back up camera? now would be a good time to drill the hole and run the wires if you want to place it at the OEM location.
Old Aug 16, 2017 | 12:51 AM
  #446
Yes, I purchased one already. I'm just wondering if I should place it in the stock location or in the bumper near the plate....
Old Aug 16, 2017 | 04:59 PM
  #447
DShiekhi's Avatar
Forum Member's Mercedes-Benz G500 Build Gets TLC and Much More
MB World's Kobzarhomes is doing a great job of upgrading and customizing his 2002 G500 inside and out.
Read the rest on the MBWorld.org homepage. >>
Old Aug 16, 2017 | 10:39 PM
  #448
No more gray interior parts in this car, 5th door interior handle "black".
Installed door latch, wiper motor, brake light and closed cell foam.
Old Aug 20, 2017 | 12:07 AM
  #449
Installed few more new parts on the 5th door.
**So apparently they use "red" thread lock on this little stub. When I went to unscrew it, the inside bolt spun. I ended up making a hole to access the bolt so I can remove the old stub and install a new one. After I took this photo, I treated the bare metal with paint and installed a rubber grommet. Eventually this will be covered with trim.
Old Aug 20, 2017 | 11:19 AM
  #450
invictusmaneo's Avatar
Lifted G500, GT-S, track Cooper S
FWIW, I have one added aftermarket, and down at the plate level it has great visibility. I have a 33" spare and lift, but the top location to me seems like it would have impaired visibility compared to the plate area.
