Tire Pressure for GL 550
very confusing, the inside door signage has 39psi front 47psi rear, the inside gaz cover signage has 32psi all around, any thoughts on why they are different and which one to follow.
2015 Ram 2500, former 2013 GL350, 2007 GL450
Wow, that's interesting, I have to check my GL350 now. Maybe the 3rd option would be to see what pressure they have by checking the TPMS?
I'll let you know what mine says.
Am I missing something? the following pictures shows the gas cover and inside B pillar tire pressure which are different, in addition the dealer said it should be 33 psi all around, so go figure...
I don't have an answer but would seem the fuel tank door doesn't account for 21" rims. I believe there was similar confusion on the W212s when they came out...
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Sounds like the two postings are NOT talking about the same tires! The higher pressures would be for lower profile 20+ in tires. The GL ( all models) can handle anything from 18 to...what is the upper limit on the 550 21 or 22? One of those stickers relates to the tires you actually have on the vehicle!
Forget the pillar pressure markings/decal they are nonsensical in all MB models.
Shipped from factory at 42lbs PSI for shipping - to be corrected before delivery by the dealer - many dealers do NitoFill for correction/full evac/refill up on a rack to do that
Inside fuel filler door are the accurate factory "recommendations" for your specific model and tire set- however I recommend you start at +4lb PSI - run for a full week, then reduce by 2lbs and try that for a week - then decide which direction you prefer and go from there.
The TPMS is very sensitive so it can react quickly to a drop in pressure - so as a result TPMS is also sensitive to temperature/pressure changes - so too sensitive for general tire pressure setting/work - hope I have expressed myself well on that.
the pressures mentioned are for the same rims and tires- normal load is 32-33psi and for heavy loads or for driving around or over 100mph you need to add more air- which is where the 47psi is recommended..
hope that helps..
hope that helps..
2013 GL450
I have the 19" wheels and use 33 all around COLD. When driving for 30 minutes or so, during this time of year (it's COLD out) they are running at 35. I did this based on a light load (just front passengers) and the gas filler door suggestions. I may boost it a bit to 36 cold in the rear, but that will be about as high as I go. That will be to accommodate four passengers. To me, the important thing is to not have pressure below 32 and to have it balanced.
Lower air increases chance of hydroplaning, and increases tread flex lowering cornering traction.
About the only improvement from lower pressure is ride quality.
2013 GL450
You can use an 18" wheel on the GL
At one point, 18" was standard. But, everybody wants the low profile look. With snows, a taller and narrower tire is better. Went with an 18X8 Falken wheel with a 265/60R18 Falken Eurowinter HS449. This is almost exactly the same as the size you have when you buy the 19" wheels with the standard Conti factory tires. Basically, a smaller wheel and a taller tire. Speed readings should be about the same.
I have the 19" wheels that came with the vehicle as I like the ride over what you get with the 20 or 21 inch wheels.
I am not as concerned over the look as I am getting a ride that I like. Everyone has their own preferences and it seems that is why there are so many options.
2013 GL450
18" wheels are a bad idea.
Don't go with 18" wheels. They won't fit the front due to the size of the calipers. I had a fun day wasting my time trying to install them.
18 was standard on 2008. I have the Datacard to show that is how the one I am buying is equipped.
EDIT:
Oops, DId not notice this as X166 forum
Datacard
Identification number: 4JG1648221A
Sales designation: GL 320 CDI 4MATIC
Order number: 0 8 714 00494
Delivery date: 10 12 2007
470 TIRE PRESSURE MONITOR (TPM) LOW LINE
494 U.S. VERSION
690 EMERGENCY SPARE TIRE (MINI SPARE)
705L UNITED STATES (USA)
7XXL NORTH AND SOUTH AMERICA
M642 V6 DIESEL ENGINE OM642
R02 ALL SEASON TYRES
R31 18" LIGHT ALLOY WHEEL 5-SPOKE DESIGN ALL-ROUND
V41 SPEED+ - LOADINDEX 110 H
494 U.S. VERSION
EDIT:
2013 GL450
Yep, 18" used to be the standard.
Yes, it was standard at one time on the X164. Now, on the X166 model 19" is the smallest wheel due to front brake caliper size. That is why I tried it and it was a dumb idea for the 2013 GL.
2015 GL550, 2019 GLC350e
Having 47psi is a bit high though....
my GL550 just started saying "correct tire pressure" on the display when turning the car off. it displayed anywhere from 31-33 psi for the four tires.
if i use the gas cap recommendation, then i shouldn't have had to pump any air and the display would continue coming on. so i filled them to the pillar recommendation for front/back, which seems high, but the car is riding fine and if anything i hope to get a little better mpg.
this is the first time since taking delivery on 5/11/13 that i've filled any air.
