SOS Teleaid malfunction fault is driving me NUTS !!
My car is a 2006 E55. I have searched and done everything with my STAR unit as best as this STAR beginner can, and I can't get rid of this damned SOS Teleaid malfunction fault code. I clear it with STAR and it immediately comes back. I have no intention whatsoever to use this system; I never have and I never will use TeleAid. I have read that there is a way to disconnect it permanently from the car's system using STAR so that it is invisible to the car and won't ever trigger a code again. I can't figure out how to do that.
So, in some sort of order, here's what I have. I have the SOS TeleAid warning on the instrument cluster.
When I check the codes, it shows:
D612 - Component GPS antenna or the lead has a short circuit.
D632 - Component TELE AID spare antenna is faulty or the lead has open circuit.
I clear them and they reappear immediately. Again, I couldn't care less about the system functionality. I would only repair this if that is the ONLY way to get this damned warning to stop appearing in my instrument cluster.
Here's the kicker - when I delve deeper into the menus, I eventually get to this page:
"The Digital TELE AID control unit is DEACTIVATED.
This is not an error of the TELEAID control unit.
The TELEAID Services (for example :M-B info, Roadside assistance) work only when the unit is activated.For further assistance call: .........."
Does this mean that someone has already "disconnected" electronically through STAR the TeleAid system on my car in the past, or are they referring to my car's TeleAid not subscribing to the system at this time? This whole thing is driving me batty.
Can any of you STAR gurus give me a STAR for dummies step by step procedure on how to finally get rid of this warning? I'm just learning STAR, as I just got it up and running yesterday. I know some will yell "DO A SEARCH !!!!!!" I did. I found one procedure to lead through the manus, but my menus were different. I don;t know if my car is different from the car used in teh example, or STAR has changed from 2009 when that write-up was from. Any help would be appreciated. Thanks!
Sometimes you got to search the non AMG W211 forum https://mbworld.org/forums/e-class-w...-workshop.html
Thanks for that but.......
I'd really like to use STAR to just bypass the unused SOS Teleaid system forever. I have read it can be done, then I won;t ever have to worry about this "splitter" and cable again. Does anyoneone know how to bypass this system permanently using STAR?
Star
I was able to disable mine with Star....but I believe I used the developer mode portion of STAR/DAS to do so.
I genuinely don't remember the steps, but I just followed the info that I found from this forum. It may have been in the sticky section above.
The faults will still show if I do a scan with Star, but the dash no longer gives that annoying message.
That's exactly what I'm looking for! Now, does anyone know how to do it????
Received 1,014 Likes
'99 and '05 E55 AMG
Two possible approaches.
First:
-Main Group
-Control Units (Should take you to CGW)
-Information and Communications
-Audio, Visual, Navigation, Telematics
-Set Teleaid to "Not Fitted"
Second:
-Main Group
-Control Units
-Body
-CGW
-Control Unit Adaptations
-Read Coding and change if necessary
-Telecommunications
-Telematics Service
-Set "Telematics Service 'Tele-Aid'" to "Not Present"
If you continue to get an alert, then you need to look at pulling the fuse that powers the telecommunications control module that connects to the emergency notifications switches in the console.
Please provide feedback on how this works. I've done it once but had to pull one fuse to kill the SOS alarm (literally a beeping noise) and I can't remember which fuse it was except that in this case it was in the driver's side dash fuse box.
First:
-Main Group
Second:
-Main Group
-Control Units
-Body
-CGW
-Telecommunications
-Telematics Service
As Barry said....The Star Bulletin is below....
2) Model 211: In Star Diagnosis, please navigate through the following menus: Control Units > Body
> CGW (Central Gateway) > Control Unit Adaptations > Read Coding and Change if Necessary
> Telecommunications > Telematics Service “Tele Aid” in combination with MOST technology.
3) Change the coding from PRESENT to NOT PRESENT.
4) Once the coding is done, cycle the key to ensure that the message is disabled in the instrument
cluster
cluster
Thanks so much guys - that's exactly what I was looking for. I just got home from work, I'll try it all out tomorrow and let you know how it goes.
Thanks for all the help, guys. I finally got to do this, and it worked like a charm. For those who have this issue in the future and find this thread using the search feature, here's the procedure that worked perfectly on my 2006 E55:
In Star Diagnosis: Control Units –> Body –> CGW (Central Gateway) –> Control Unit Adaptations –> Read Coding and Change if Necessary –> Telecommunications –> Telematics Service “Tele Aid” in combination with MOST technology.
You will need to change TeleAid coding from PRESENT to NOT PRESENT and the error on the instrument cluster will no longer appear.
bbirdwell (11-13-2018)
'99 and '05 E55 AMG
2005 S55, 2002 E430, 2007 CLK350, 1981 380SL
I know this is an old thread, and I have the Star system and can navigate tho these menus...but my system seems to hang and never completes the process it just shows a message "Coding in process...please wait". I have waited over 30 mins and it seems to never finish and finally goes to "Not responding" in windows...is it some step im missing?
Mike
Mike
'99 and '05 E55 AMG
I'm confused by your question. STAR/Xentry is the external diagnostic tool used to code the modules. If, by "gps control panel", you mean the COMMAND navigation screen on the center console, COMMAND has nothing to do with coding the modules.
The following 2 users liked this post by bbirdwell:
ls1_mast (08-08-2024),
nd-photo.nl (08-08-2024)
My GPS randomly started working again today and I acquired up to 10 satellites on my drive back home from the eye doctor. I hope this stays a while. I really don’t want to go through the hassle of replacing the splitter/antenna!
'99 and '05 E55 AMG
I would take this as a poor connection on the antenna leads. Unlikely the splitter failed; more likely a corroded connection. Multiple times in the military I would tell folks to check the Oscar/November switch (ON/OFF). Happened more times than you would think. Antenna coax disconnected or loose was another time waster...start simple.
