GT63 Pro
The following 2 users liked this post by thebishman:
California John (07-13-2024),
Drone_S213 (07-12-2024)
Received 2,789 Likes
I love how they don't mention any weight savings....
MalibuScott (07-12-2024)
Here's the promo vid. Exhaust sounds a bit flappy. Is that the sound even on the non-pro?
I am still baffled by the two radiators in the wheel arches. Are these in addition to the center radiator? If so, does that mean the regular GT55 and GT63 just rely on a center radiator?
Don't all gen 1 GTs have additional cooling in that area?
The key reasons I purchased my GTR Pro were limited production (significantly less than even the BlackSeries that came out the following year), meaningful weight and aerodynamic improvements, and significantly better track times than the GTR model.
Based on the write up, the new one lacks some of the attractive qualities of the original one. Will be interesting to see the comparable track times…if Mercedes doesn’t test it at the Ring, that will speak volumes. Or if they test it, but use the Cup tires on the 2021 Balck Series which are worth 8-10 seconds at the ring over the Cup tires that came stock on the 2020GTR Pro.
The numbers won’t lie and looking forward to seeing the weight savings as well.
Case1906 (07-13-2024)
sevenhead (07-14-2024)
Marketing, marketing, marketing.... I think that the difference with the GT63 is only in the front bumper and more expensive options in the base (carbon- ceramic brakes, aerodynamic package, etc.). I wouldn't be surprised if in fact it turns out that the engine has the same power...
You can find info in the link on the GT-S cooling system including a diagram of all the 7 air to fluid radiators in the front of the car. There are also two fluid to air coolers for the charged air and two fluid to fluid coolers for the transaxle.
I have not seen cooling diagrams for any other models than the GT-S.
https://mbworld.org/forums/coupe-roa...me-racing.html
thebishman (07-15-2024)
Received 4,009 Likes
2017 GLE350 4MATIC
Cayennes have intercoolers in the lower outboard fascia openings. Primary engine coolant radiator (and condensor) are in the usual center position.
Super Moderator
Received 3,339 Likes
So now it makes the same hp/torque as the E63s while weighing 100-200 less than the sedan.
It‘ll be interesting to see any Nurburgring time, perhaps by Christian Gebhardt who ran the first great GTR lap time.
The following 2 users liked this post by Wolfman:
Drone_S213 (07-17-2024),
‘24 BMW iX M60
TtimeAMG (07-15-2024)
Comes with Cup 2Rs --sweet!
But if you track like I do over 40 days per year get ready for spending money on tires. My 2 Corvette C8 Z06s that I track came with Cup 2Rs and get only 2 track days out of them--maybe three with a Tirerack cost of about $2600 a set. I hope the AMG Driving Academy (now AMG Experience) has these cars on the docket for COTA and Road Atlanta coming up this fall so I can drive either the new AMG GT 63 (hopefully the Pro as well) to see if I should buy a GT63 Pro. I have been participating in AMG Driving Academy Pro and Pro Plus classes for a number of years with the GTs and GTRs so I would like to see how the new platform stacks up!
thebishman (07-16-2024)
