Need help!! Trying to figure out why 2012 c250 won't start!
Hi guys so I drove down the street the car started fine on the way to an appointment then I go to leave and nothing. It wouldn't even crank with a jump box so I put a new battery I had in and same thing. All lights are on on the dash. My only guesses are a fuse or relay which I'm checking momentarily, I have an oil leak that may be dripping on the starter is my second guess and 3rd it's this ESL fail problem I keep reading about. I do have an esl emulator box on it that was put on before I got the car. Any insight would be greatly appreciated!
That is hugely helpful. I did the jump on the relay yesterday and nothing happened but it was with a crappy wire and I didn't have the fuse plugs on the ends of the wire, I just smashed the ends so they were flat. I'm going redo that today with the fuse plugs connected to the wire but since that first one didn't work I'm really thinking it's the starter. Thank you so much for the reply!
2013 w204 c250 coupe & 2001 Dodge Ram 2500 24v Cummins
@Phoenix222 hey, Did you try tapping on the starter while cranking to see if it would start? I've had to use that truck on my 2nd Gen Cummins to get home before.. The oil leak likely killed your starter which it sounds like that is your main problem. I'm not familiar with the ESL issue. My oil filter housing was leaking onto my starter as well and I replacedthe OFH gasket and my leak was fixed. I believe I saved my starter by stopping that leak.
antboii (07-29-2024)
lol! I tried that trick from my old Chevrolet days, but no-go. At a minimum, I think the oil filter housing leak killed the solenoid since I didn't even hear the click. Fix the leak while you are in there to prolong the life of the new starter. You have to remove the starter anyway to replace the oil filter housing gasket (I wish it were like the M276 with the filter housing on the front).
I agree @alynch ! The oil leak likely killed Phoenix starter. The OFH is right above the starter and leaks right on to it.
Would of been nice if MB thought that placement through lol
Ant
That's was my thought ill just replace the OFH. I was going to do the gasket but I noticed a crack in the OFH while I was under the car looking at the starter so I'll just replace the whole thing. Also I did try hitting the starter a little but it didn't even make a sound. I got a click a couple times when trying with the new battery in but then nothing after that.
Does anyone think it's a good idea to go get my starter tested? It seems like its a pretty definitive that the starter is bad considering it didnt even make more than a click when tapping on it while someone tries to start it. I just got it out today and it wasn't too much of a pain.
