SL/R129: Center Console
(For the age of owner thread, my friend got the car last year when he was 40.)
To remove it (deep breath)...
1. Remove the radio
2. Reach in and release the latches holding in the air con controller
3. Pull out and disconnect
4. Open the compartment in front of the shift lever
5. Remove the screw in the bottom of the lining
6. Fold down the plastic sides of the lining (plastic hinge along the bottom) and remove the exposed screws
7. At the back, open the storage bin and remove the 4 screws inside holding it in; remove it, disconnect the central locking connector
8. Lift up the rear section, disconnect, this will expose the 2 screws holding the back of the front section. You can then ease out the centre console
That's it. Just remember you do not need to use force for anything. If you are, you're not doing it right. When putting it all back together, make sure no cables are snagged.
http://www.youtube.com/user/tamango#
1. Remove the radio
