SL/R129: 2000 SL 500 Options?
I just found a pristine 2000 SL 500 in Silver/Ash with the AMG Sport Package, 52k miles, not a scratch on it. But I was disapointed to find out that it didn't have the auto/stick and it had the blade type igniton key.
Were these options on the SL or were they not offered on the SL in 2000? Seems to me a high line car like that would have had the latest in technology MB had to offer.
I'm still considering buying the SL, but I've gotten so used to these two features on my C230k, that it would feel like a step backwards without them.
Thanks for any input.
Go ahead.... ask me about my Glocks.....
As to the tiptronic-style shifter, that was another thing that never came on the R129s. That, however, I don't miss. They don't do anything differently anyway, since it's still a fully automatic gearbox, not a computer-controlled manual like in the Ferrarri F1 editions, or BMW's SMG system. Personally I like having the car do the work for me.
Thanks for the info!
P.S.: The car looks just like yours except for the 2 pc rims, Beautiful!
In the newer models, Mercedes referred to it as Touch Shift, and AMG's variant was labeled Speed Shift. Tiptronic is Audi/Porsche; BMW calls it Steptronic. They are all different names for the same Manumatic style transmission.
I got to admit, the electronic key thing is more snobish than anything, people look at it and wonder how you start the car with it. I was just suprised to find out that it was included in a baseline model but not the SL. But bottom line, a key is a key.
I only got to drive the car for about 2 miles on level surface streets. I realize it will be quite a performance/handling upgrade over the C230k. I just can't wait to get it up over some of the Sierra passes before it starts to snow....
Thanks.....
As for the key thing, I personally think the newer key was never implemented to the r129 because the car is rather old. The design was introduced in the late 80's and I guess it wasn't economical to change the key setup. Despite that, they at least implemented the "quick start"... just twist the key briefly and the car will start up (unlike older cars, where you have to hold the key for it to start up).
Were these options on the SL or were they not offered on the SL in 2000? Note: the car does have an auto/stick. I use it daily.
Engine: 303 cid/4,966-cc SOHC 24-valve V-8 high pressure die-cast aluminum cylinder block and heads.
SMFI: Sequential multi-port fuel injection, ME-SFI 2.0 = Motor Electronics -Sequential Fuel Injection, two plugs/cylinder (Bosch F8DC4)
Net Power: 302hp @ 5,600 RPM
Net Torque: 339lb-ft @ 2,700-4,500 RPM
Compression: 10:1
Transmission: Driver-adaptive electronic 5-speed with Summer/Winter(starts in second gear)
Rear axle ratio: 2.65:1
Curb weight (lbs.): 4125
Acceleration (0-60 mph): 6.1 Seconds
1/4 mile (E.T.): 14.5 seconds @ 97.2 MPH
Top speed: 155 mph
Fuel capacity (gal.): 21.1
EPA fuel economy, city/hwy/avg (MPG): 16/23/20
Bose Accoustmass seven speaker 200W system with speed-dependent volume control.
Electronic Stability Program (ESP)
Heated Outside Mirrors
Rain Sensing Wipers
SL500 Package Options
SL1 Sport Package ($4,995)
AMG designed sculpted lower body aerodynamic enhancements, to include:
Front apron with mesh air intake, two seperate tow hook covers
Contoured rear apron
Sculpted side skirts with Sport emblem
Halogen projector-beam front foglamps
245/40ZR18 front and 275/35ZR18 rear, low profile high-performance tires 33/36 PSI
8.5Jx18" front and 9.5Jx18" rear, staggered-width AMG I 5-spoke monoblock alloy wheels
$780(part #66031008) front and rear $830(part #66031009)
Front offset 25 mm & Rear offset 23 mm, with 5x112 mm bolt pattern
Note: Suspension and steering calibrations are unchanged by the Sport Package.
SL2 Value Added Package ($1,820)
Xenon headlights w/ automatic level control w/o headlight washer/wiper
Integrated trunk-mounted 6-disc CD changer, OEM p/n 0028207989 model# MC3198, CD magazine p/n 0028206289
Electrically heated seats
Special Order Options
Wood and leather trimmed shift knob
Wood and leather sterring wheel ($1,800)
Multicontour Seats ($710)
Panorama glass roof p/n 1297902540 ($3,695)
Adaptive Damping Suspension System (ADS) approx. $4K-$5K
