SL/R129: Rattling sun visor - can it be fixed
http://www.benzworld.org/forums/w210...ml#post3203138
you can pop it out with a sharp edge. The encasing may be wired to the visor so don't yank it out. (In a '86 420SEL, the encasing is glued to the visor and there is a short length of wire connecting the encasing to the visor, for power.)
You can check this easily - hold the visor up against the windscreen top rail with your hand a drive over a rough section of road. If the rattle goes away, this is your problem. If not, there may be something loose inside such as the bulbs or other bits. BTW, it should rattle a lot less with the hard top on because the structural rigidity of the top greatly reduces the cowl shake in the car.
Good luck.
- FD
