SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: SL500 first timer doing oil change from the top.. help?
Old Sep 4, 2017 | 09:35 PM
Andrea Grandone's Avatar
sl500
Hi
I bought an oil extraction pump but the plastic tube is too big in diameter to go down the oil dipstick guide tube. Now I was wondering if I can just attach it to the dipstick guide tube and seal it and if that will create enough of a vacuum or do I need a smaller diameter tube that will actually fit into the dipstick tube guide until I hit bottom?
Many thanks in advance for the replies. I'm in the Los Angeles area if that helps (think I saw talk of "the more details the better" while reading many threads on this forum)
Old Sep 4, 2017 | 09:43 PM
ItalianJoe1's Avatar
2003 CL 600
Yes, if it seals at the top of the tube it will draw it out just fine, that's how we do it at the dealership.
Old Sep 4, 2017 | 10:00 PM
sl500
thanks a million for the quick reply! Grazie mille!!
Old Sep 4, 2017 | 11:04 PM
sneezix's Avatar
1997 SL600, 2017 AMG GTS
Does the dipstick tube go all the way to the bottom of the oil pan?
Old Sep 4, 2017 | 11:52 PM
2003 CL 600
If you have the large tube, yes. Some of the newer engines, rather than the big 3/4" opening, they stay small all the way up. This is an indicator of not being able to use vacuum extraction. On those, we use a small tube to go down to the bottom of the pan.
Old Sep 15, 2017 | 10:18 PM
SRHsl600's Avatar
94 SL 600, 98 993, 89 XJS Conv., 85 Daimlier Princess 16 Hybrid Lincoln 16 Chevy crewcab
still the low drain plug
If you will, please educate me about the benefits to the suction extraction on the M120 engine.
Thanks in advance
Old Sep 16, 2017 | 04:16 PM
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
Thanks in advance
It's quicker, easier and cleaner. You don't have to jack up the vehicle, remove things and get burned etc. Been doing from the top for over 20 years. The only way to fly.
Old Sep 16, 2017 | 04:20 PM
This is what I use. The 20 gallon unit. JDI-20EV
http://www.johndow.com/pages/JDI-6EVJDI-20EVJDI20EVB
