SL/R230: Where is the aux input for ipods in the glove box?
Old Aug 22, 2006 | 04:47 PM
shoozlover's Avatar
2007 SL550 2008 GL550
I seem to remember someone mentioning this. I didn't see anything in the manual.
Old Aug 23, 2006 | 05:54 AM
Third SL's Avatar
Previous SLs: 1965 230SL, 1969 280SL
On the left just inside the glovebox is a jack point. You insert the cable from the iPod into that jack point (I bought a small jack point cable to run between the two). You then use "svcs" button on the dash Comand module to get to "aux" and this tunes to the iPod. Works great. I can alter the volume using the steering wheel controls but not switch between files etc. Good luck.
Old Aug 23, 2006 | 06:51 AM
detailas's Avatar
2003 SL500, 2001 Jeep Grand Cherokee Limited
I (think that I) have read somewhere in this forum that this feature does not exist in the post-2004 models, but I am not certain. However, for the SL's that have it, it is indeed as per "Third SL"s post.
George
Old Aug 23, 2006 | 01:56 PM
joec1101's Avatar
'09 E93 335i
MB deleted the aux input jack in models produced after about mid 2004. Why? I don't know. They seem to take away some of the best options just like they deleted the ability to switch between radio presets using the steering wheel up/down buttons. Now it just scans up/down to the next frequency.
Old Aug 23, 2006 | 05:09 PM
elbowyeish's Avatar
SL55 AMG Black on Berry Red
exactly. if you open the glove box, you will see the aux input on the left wall inside the glove compartment. it is also in the manual but it's only one little sentence that references it. hope this helps.
Old Aug 23, 2006 | 08:06 PM
benzmodz's Avatar
W203 slightly modified
If the car has a trunk loading map DVD then it is the version of the car that doesnt have AUX on the head unit.
Old Aug 24, 2006 | 07:34 AM
prsmith777's Avatar
06 Infiniti FX35, 07 SL55
I think it was deleted when the NAV was upgraded from CD based to DVD based. At that time they upgraded the fiber optic network to MOST from DB2. The aux input was taken away in favor of the DVD NAV on the network. I dont understand their reasoning because I thought their network is a fiberoptic ring and could handle the extra node.
Old Aug 24, 2006 | 07:43 AM
benzmodz's Avatar
Before the end of the year you will be able to use an iPOD in a MOST car with a Siemens head unit.
The Siemens head unit is the one that is widescreen and does not have an AUX jack.
Dont assume that the head unit is perfectly stable with a large number of nodes. This is a matter which is hotly contested between head unit makers.
Old Aug 27, 2006 | 05:52 PM
CarGod's Avatar
2003 Sl500
What type of sound quality do you recieve from this? I just looked in my glove box and see the input, its one small hole right? Like where you would plug in a small headphone jack...
I know mp3's vary in quality, but assuming I have good quality mp3s.. do you still get good sound?
