SL/R230: SL roof open/close while driving?
Old Feb 21, 2007 | 12:30 PM
shahedC's Avatar
OLD: 2004 C230 Sport Sedan, NEW: 2007 SLK350
Hey guys, do any of you have this installed from Piecha? Apparently, you can open/close the roof of the SL/SLK/CLK while driving.
Video from piecha.com:
http://www.piecha.com/02b77898be08b6...f06f/index.php
I used Google to translate and I got this:
For SLK R171, SL R230 and CLK W209
Gönnen it itself finally the luxury to be able to open while driving and by remote maintenance the Variodach!
The comfort Variodach module is conceived and suitably for all SLK R171, CLK 209 and SL R230.
EMV examined with very small power input (under 0,8mA). An TÜV entry is not necessary
We revised our comfort Variodach module into a Plug & a Play version (simple patch cord) completely and built some product improvements, which were to date not yet available. The expenditure of time for the installation amounts to approx. 20 minutes and represents owing to detailed and understandable fitting instruction no problem. No cables for the installation must split to become. The module can be at any time again without trace developed.
Here you experience more over our comfort Variodachmodul!
Video tie-clip in the quick-motion apparatus
Old Feb 21, 2007 | 01:27 PM
Murtaza's Avatar
C63S coupe, X5M
A friend of mine has that for his SLK55, he totally loves it and has had no problems.
I ordered this one yesterday:
https://www.wilhelmy-it.de/sms/shop/...roducts&cat=23
Old Feb 21, 2007 | 01:30 PM
shahedC's Avatar
what's the name of the product you got? the site doesn't seem to allow a direct link like the one you specified... so i have to go search for it through the main site...
Old Feb 21, 2007 | 03:26 PM
Murtaza's Avatar
C63S coupe, X5M
Just go to MB > R230
smartTOP for Mercedes Benz SLK, CLK and SL
Old Feb 21, 2007 | 04:11 PM
shahedC's Avatar
so, where can I get it installed after I order it?
What exactly am I going to get in the mail?
Finally, can I open/close my SLK roof while driving? The video only shows the SL.
Thanks,
shahedC
Old Feb 21, 2007 | 05:01 PM
joec1101's Avatar
'09 E93 335i
Why would anyone want this?
Aside from the safety factors, opening and closing the top while the vehicle is in motion could cause damage to the roof and its moving parts. There's a reason why it's made from the factory so it can't be opened while driving!
Old Feb 21, 2007 | 05:47 PM
rajah996's Avatar
CLK55, CL500, Q45
The only benefit to this would be the one touch feature.
That is the only reason I am considering the device.
Old Feb 22, 2007 | 09:52 AM
shahedC's Avatar
How about if I am going in 20 mph suburban traffic... I wasn't sure if it would still cause damage or not...
Old Feb 22, 2007 | 12:05 PM
rajah996's Avatar
CLK55, CL500, Q45
It wont be as bad as going 40MPH, but I am sure overtime
the added stress will cause parts to fail prematurely.
Old Feb 22, 2007 | 12:43 PM
Murtaza's Avatar
C63S coupe, X5M
People who don't like to sit in there SL and hold back a switch for 16 seconds everytime they want to raise/lower the top Being able to access the hardtop using the fob is going to be liberating.
I see what you're saying about using it while moving, I probably won't be doing that above 5-10mph...
Old Feb 23, 2007 | 05:25 AM
R230_Nicke's Avatar
SL 600 640bhp/1000Nm
I have it and I love it!
When i exit the car I push lock on the key two times and the roof closes as i walk away.
The otherway around when i get to the car. Or get in the car and use the one touch function while driving away SLOWLY. I have mine set to a maximum speed of 30 km/h (20 mph ?). But I use this function as little as posible since I think it would damage the roof.
Installation is easy, it took me about 45 minutes.
Old Feb 23, 2007 | 10:18 AM
shahedC's Avatar
Could you please describe the installation procedure?
Also, if I install it on my R171 SLK, will it be just as easy?
(Keep in mind, I am not much of a car guy, when it comes to working on cars)
Old Feb 23, 2007 | 11:06 AM
Murtaza's Avatar
C63S coupe, X5M
There are online instructions to install it for the SL/SLK/CLK here:
https://www.wilhelmy-it.de/sms/db/sm.../en.php?mode=1
Old Feb 23, 2007 | 01:19 PM
shahedC's Avatar
Hmmm.. maybe I can ask a knowledgable person to help me out with it... I wouldn't want to install it myself...
Old Feb 23, 2007 | 05:41 PM
gqa's Avatar
gqa
05' sl 500
vario-roof
hey guys has anyone here purchased the roof module from this site? its only $200, takes about 15 mins to install, and the programming is in your heads up display in the dash.
let me know. im about to purchase!
Old Feb 23, 2007 | 07:42 PM
Murtaza's Avatar
C63S coupe, X5M
Mine gets here on monday, should have it in that night or on tuesday, i'll post about how it goes
Old Feb 24, 2007 | 01:06 PM
gqa's Avatar
gqa
05' sl 500
please keep me posted murtaza so i can purchase one. thanks
Old Feb 28, 2007 | 06:10 PM
Murtaza's Avatar
C63S coupe, X5M
Just finished the install. It took about an hour. I've only tested a few things so far and they all worked.
If I had to do it again, it would take about 15minutes Most of the time was spent figuring out how to fold up the carpet. Once that was taken care of, the rest was easy.
Old Feb 28, 2007 | 10:40 PM
gqa's Avatar
gqa
05' sl 500
cool, so besides the carpet are there any other pointers?
so it does they same as the other roof module's and is at least 1/3 cheaper?
Old Mar 1, 2007 | 01:18 AM
Murtaza's Avatar
C63S coupe, X5M
Some pointers:
Make sure you have lots of light. I installed mine with the top down, doors open on a bright sunny day and still didn't have quite enough light. Get a flashlight.
Remove the plastic covering by grabbing both sides of it and pull hard, don't worry, you won't break anything. I wasted a lot of time being carefull...
For step 7, ignore the manual when concerning bracket removal. I struggled with it for a few minutes and then eventually, out of frustration, I slid it upwards to see what would happen. It slipped right out
For steps 8 & 10, ignore the manual (visually). It shows the brown and black wire as being on very left side. Mine was 3rd from the right. Just make sure you disconnect the brown and black wire and not the others.
Think thats it, let me know if you have anymore questions
Old Mar 1, 2007 | 11:14 AM
shahedC's Avatar
Originally Posted by Murtaza
Some pointers:
Make sure you have lots of light. ...
Well, I also have the illuminated doors sills installed on my SLK... will I have problems with it?
Even the professional Mercedes techs took all day to install it when I went to pick up my car on the first day.
Old Mar 1, 2007 | 02:07 PM
Murtaza's Avatar
C63S coupe, X5M
I don't see how, you don't have to remove the door sills. It's a plastic cover next to the door sill...
Old Mar 1, 2007 | 02:26 PM
shahedC's Avatar
oh ok thanks.. I didn't know which part I would have to remove... I just didn't want to mess with something that took a long time for the pros to install...
