SL/R230: Steering Wheel Vibration
My ABC pump pushed vibration into my steering when it was failing
in my CL. After awhile it started humming with RPM.
It will get worse quickly if thats the case.
More likely a simple balancing problem - in my experience it pays to shop around for a professional outfit with propely calibrated equipment as most tyre shops are USELESS GREASE MONKEYS they take no care of their equipment and offer useless shoddy service.
Luckily where I live there is a company called ProTyre and their service is second to none - will always use them to cure wheel/tyre issues.
Hope this helps!
Khushy
PS - if the steering wheel only wobbles when you are using the brakes - your rotors are shagged!
This is a constant vibration while driving.
The real break through was replacing the front control arms and/or bushings. It seems the SL600's turbos run VERY, VERY hot and will over time melt or compromise the bushings. I asked my dealer to check them and they actually replaced the whole arm under warranty. I learned this relatively common problem with the 600's. The car now runs smooth, smooth, smooth as silk.
Check the bushings and I'll be $1 that is what the problem is.
I'm having RennTech do a THOROUGH check of my car before she goes out of warranty this fall.
Steering/Brakes - Steering Wheel 'Twitch' When Braking
Date: January 10, 2006
Order No.: P-B-33.15/16a
Supersedes: P-B-33.15/16 dated November 11, 2004
Group: 33
Revised:
Applicable Models, Model Years and Warranty Information Updated
SUBJECT:
Model 211.026/056/065/070/076/256/265
Model 230.474/475/476/479
Model Year 2003 through 2006
Steering Wheel Twitch During Brake Application
If you receive customer reports in the above model vehicles of a steering wheel twitch during slow speed brake applications, replace the hydro-mount or partially hollow rubber style bushings (which ever equipped) with solid rubber bushings. Reference the following WIS documents AR33.15-P-0160R (torque strut removal/installation) and AR33.15-P-0160-02T (torque strut bushing removal/installation).
Note: Do not replace the torque strut assemblies. Only replace the left and right torque strut bushings.
Note: The steering wheel twitch condition can usually be maximized during slow speed repetitive brake applications, such as those encountered during stop-and-go traffic or toll booth scenarios. Since ambient temperature may influence the overall affect of the condition, it is important to verify the condition only when the vehicle's engine temperature is at normal operating temperature. The steering wheel rotation/twitch can occur during brake pedal application and or release.
Note: It is imperative that the condition be verified on a smooth, flat and level road surface, failure to observe the aforementioned conditions may result in needless replacement of the torque strut bushings.
Note: The originally equipped torque strut bushings (hydro-mount or partially hollow rubber) can deform under braking applications, resulting in left or right steering wheel rotation. The solid rubber bushings have an increased resilience towards deforming during suspension loading.
