SL/R230: are these tires repairable?
Got a nail, it seems, slow leak out back, dont like the idea of running a new tire with 3 used ones, so Im hoping I can save it. Will these Pirelli's accept a plug?
One shop said yes, another "not reliable, buy a new tire", who to believe!
(by the way, Is this topic misplaced? sorry if it is)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
CLS63, GLK350
Ya, its gone, nothing in stock so they ordered one to arrive tomm.
Got a question for you carnuts: Id like to have them install the new tire on the side of the axle that does the most spinning since it wears more rapidly, the "drive wheel" if there is one; as you know they dont come with limited-slip diffs so I assume both rear wheels dont do the same work, one must (!?) be favored over the other, but which is it-- drivers side or pass-side? If they both spin with equal force/speed when you step on it then what do lim-slips do differently?
Can anyone enlighten me soon, tire goes on tomm am.
-Should I have them put it on the left, or on the right side.
-Or doesnt it matter.
Oh, and is it OK to move them side-to-side once used?
Is it important to ensure direction of rotation remains the same?
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
A LSD basically allows both of the rear wheels to be able to transmit the torque. Make sure that the tires are rotating in the proper direction.
CLS63, GLK350
It's not going to mak a big difference. Your going to be rotating in 8-10K miles. But let us know if it really does wear faster. I've always found the fronts wear faster then the rears unless you burning rubber all the time.
SL2003driver, not sure about pre-07 models, but for 2007 the SLs have larger tires on back than on front, so there is no rotation possible. You just leave them till they wear out.
I want to put the new tire on the "drive wheel", but which one is that, drivers side or pass side? My drivers side tire got nailed.
ps:anyone want to buy a scarcely used almost perfect 285/35 ZR18 97Y Pzero Rosso, b.r.o.
1 Post
SL500, GL550, Escalade, 66 Corvette
2007 SL550
Don't mean to hijack the thread, but I'm confused. SLs don't have limited slip? I know that if I turn off the traction control and floor it, the car paints two nice black marks on the pavement. How is that possible without limited slip? From another thread, I also watched this video of the poster launching his SL with the same result. ![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
http://www.youtube.com/watch?v=ApBD5YvaHNI
1 Post
Limited-slip means that both wheel get the same amount ofrotation applied from the differntial. Before limited-sli,p the differnential would supply power to the wheel wish the least resistance and only one wheel would spin. The MB traction control keeps both tires from spinning for maximum rubber-to-pavement contact and better acceration. Turn the traction control off, and both wheels will spin.
