SL/R230: Battery tender
Old Dec 28, 2008 | 11:33 AM
Boulder GT3's Avatar
E320 CDI, SL550, clk550
Battery tender
I'm not going to be driving the SL55o for a few months. If I connect a battery tender to the starting battery will it charge the aux/trunk battery as well? Thanks
Old Dec 28, 2008 | 02:16 PM
R230_Nicke's Avatar
SL 600 640bhp/1000Nm
I dont think so.
I use two chargers when I winter store my baby now.
Last winter I only use one tickler to the front and and the rear was out when I started it up a few months later.
Nicke
Old Dec 28, 2008 | 02:29 PM
Originally Posted by R230_Nicke
I dont think so.
Nicke
Not what I wanted to hear but thanks for the answer. That's what I was afraid of. There is a relay of some sort that isolates the two even though some functions are on the same power bus.
Old Dec 28, 2008 | 06:43 PM
jj0822's Avatar
2004 SL55
I think I read somewhere that the starter (front) battery will eventually not draw any power and will stay charged for months. The rear battery supports the electronics and will only last a week or two. I always trickle charge the rear, but haven't needed to charge the front but it only sits for about a week or two max. The rear battery warning will come on if I don't charge it after about 5 days.
Old Dec 28, 2008 | 07:38 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
When my SL55 sits for more than 2 weeks the rear battery is the one that gets weak. I am still able to start the car, but there is the 'consumables off line" message. Within a few miles of driving it is fully charged.
Old Dec 28, 2008 | 07:53 PM
jmf003's Avatar
'03 SL55
+1. I put the charger on the rear battery, not the front.
Old Dec 28, 2008 | 10:09 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Consumables
Consumables Battery isn't that located in the trunk???
Old Dec 29, 2008 | 03:27 PM
R230_Nicke's Avatar
Yes..
Old Jan 3, 2009 | 01:21 PM
TwinCam's Avatar
2021 Cirrus Silver S580 AMG, 2020 Polar White GLE350
Best SL Battery Charger
The best way to keep your car charged while in storage is to use the CTEK Multi 3300 battery charger. This is the exact same unit sold by Mercedes, but MB parts charges a much higher price than other CTEK retailers. The CTEK is a trickle charger that electronically maintains the charge in the battery. I hooked the device up to the trunk battery in my 2007 SL600 last year while I spent the winter in Florida, 4 months later when I got back to Chicago, my SL started right up and was fully charged. I purchased my charger on line from the Home Depot who had the best price, however there are other retailers listed on line. Other friends with SL's report great results with this charger. Just make sure you attach it to the trunk battery as that also keeps the under hood battery fully charged. TwinCam
Old Jan 3, 2009 | 03:45 PM
SPIKES's Avatar
2019 S63 COUPE
i believe by charging the rear battery it keeps the front battery charged up as well.
Old Jan 3, 2009 | 06:42 PM
Right you are. I hooked up a Battery Tender to the rear battery and checked voltages 2 days later. Both full up.
Old Jan 3, 2009 | 10:51 PM
ohlord's Avatar
Make sure the batteries are fully
charged before storage,then hook up
http://www.harborfreight.com/cpi/cta...emnumber=42292
it works great.
Old Jan 4, 2009 | 09:15 AM
khaz3al's Avatar
2005 vw touareg, sl500 r129 SOLD, 2002 sl500 kleemann
what if i got the battery sign, and the consumables offline sign when i drive the car, not even off for 12 hrs or so... maybe the alternator?
what else could be the problem, now i turn on the car and it turns off by itself..
and i get the STOP turn off car sign.
anybody else has the same problem?
khaz3al
Old Jan 6, 2009 | 08:59 AM
rodin66's Avatar
E550 Cab
Can you connect this battery tender to the Convenience battery while the Conv Battery is still connected to the car ? -- Or does it have to be disconnected
While away over Xmas I connected my Porsche Battery Maintainer ( via the Cigar Lighter ) and I don't think this fed into the convenience battery --- Car still starts and runs but " Convenience Functions Temporary unavailable" -- I've tried driving the car ( albeit only 20 miles ) and Convenience Functions yet to return
My Range Rover was parked ( outside) at Newark with a Solar Powered Maintainer plugged into cigar lighter and it started up first time
Old Jan 6, 2009 | 04:36 PM
SPIKES's Avatar
2019 S63 COUPE
i have the same porsche charger from my 911 and tried it on the sl.
i found that the light under the mirror would come on while it was connected. i dont think the sl electronics like it.
Old Jan 6, 2009 | 04:48 PM
rodin66's Avatar
E550 Cab
Yes I think you're right
Old Mar 3, 2009 | 02:34 PM
brtuffli's Avatar
16 S550
concerning the above posts, an engineer from deltran (the battery tender manufacturer) opines that if you try to charge both batteries by connecting to the rear one only, you run the risk of frying the front battery if the rear one fails. he says that the battery tender will read the bad rear battery as needing more charging and the resulting increased charging will cause the front battery to be overcharged. i guess if you're convinced that both batteries are in good condition, this would not be a worry.
for what it's worth.
Old Mar 3, 2009 | 04:10 PM
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
Read this for the truth instead of a bunch of Internet opinions that may or may not be correct. Do your homework. http://batterytender.com/faqs.php?os...4a358a7302eb85
Old Mar 3, 2009 | 04:20 PM
More good info
See attachments
File Type: pdf
File Type: pdf
Old Mar 3, 2009 | 11:25 PM
funnyguy1's Avatar
2005 SL500
CTEK Charger, they run about $69 bucks. Hook it to the trunk battery and store it.
Old Mar 3, 2009 | 11:35 PM
mlandis's Avatar
2007 SL550
I don't know if the charger cable or port location will allow it, but did either of you try connecting to the power outlet in the trunk instead of the cigar lighter?
Old Mar 4, 2009 | 01:47 AM
DeLorean00's Avatar
SL500
it works great.
I have been using those for years on my Ferrari and DeLorean. Works great!! Good ol' Harbor Freight.
Old Mar 4, 2009 | 04:06 PM
mlandis's Avatar
2007 SL550
For those of us who don't have electrical outlets in garages (the joys of living in an apartment) does anyone have any product recommendations? Are solar chargers really that useful? Etc. Etc.
Thanks in advance,
Michael
Old Mar 5, 2009 | 11:30 AM
Rook3300's Avatar
2005 SL500
I'm sure you could go over to Lowe's or Home Depot and pay one of those guys standing out front to ride a bike for 9 hours and charge it up.
Rook
Old Mar 5, 2009 | 03:50 PM
Thanks in advance,
Michael
This is a good unit. I have them installed on over 100 backup generators to keep the start batteries fully charged. It has a regulator to keep from over charging. Good Luck. http://www.batterystuff.com/solar-chargers/SP-2.html
