SL/R230: TCU reset ?
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
https://mbworld.org/forums/w211-amg/...set-works.html
I was skeptical, but I tried it and noticed a difference. I am not sure how it works, but from my understanding it resets the adaptations to the ECU/TCU based on the driver's normal style that are made to improve gas mileage.
OK, actually I guess if they tuned it, they'd want the car to relearn for whatever they changed. So if they were messing with it anyways, it probably didn't hurt for them to reset it while they were at it. But I'd doubt that the dealer has to do it, just anyone who knows the reset procedure.
Last edited by mlandis; Mar 8, 2009 at 01:08 PM. Reason: Giving the dealer a little bit of credit ;)
You could try the protocol that I referenced. It won't hurt anything and you might be pleasantly surprised. If you don't notice a change, at least it won't have cost you anything.
