SL/R230: "Close Trunk Lid" but it IS closed!!
Old Aug 16, 2011 | 08:33 PM
GreazyDeigo's Avatar
2003 SL500
I put the car in drive and the dash turns red and displays "Close Trunk Lid". Sometimes it says "Close boot Lid". But the trunk is closed! I can't put the top up because it also says "Close Trunk Lid" when I hit the button to close the roof. Anybody know where the sensor is for the trunk? I'll put my finger on it and close the thing just so it's stuck closed instead of open!
Old Aug 19, 2011 | 12:21 PM
Zaddick's Avatar
2005 SL55 AMG
My trunk soft close went out. I have not done the fix yet, but I do get that message. I basically close the trunk as normal. with out the pump to pull it tight, you can tell it is sitting up high. I give it a few firm, but gentle pushes down and it engages enough to keep me from getting the close trunk lid message.
Old Aug 21, 2011 | 12:27 PM
2003 SL500
Mine is a bad switch somewhere. The trunk closes, and then pulls down into position (most of the time, sometimes it kicks back up again), but even with complete close mine still says "Close Trunk Lid". It's only a problem when I'm trying to put the top up, otherwise I wouldn't care.
Old Jun 7, 2012 | 07:38 PM
mwpersonal's Avatar
SL55AMG
"Close Trunk Lid" after soft close fix
I just finished gluing the ports on my soft close motor per another thread to fix failure to pull down the trunk lid. Now the trunk lid pulls down real solid, but I'm getting the "close trunk lid" warning. I pulled cables from both batteries and jumped + to - for 60 minutes to clear memory, but that didn't solve the problem. Does anybody know where the sensor is?
Old Jun 25, 2012 | 01:30 AM
2003 SL500
After SEVERAL trips to the mechanic, and a few THOUSAND dollars of GUESSING at the problem, I finally took my car to a new mechanic and am completely baffled at how the previous people are still in business.
Turns out in my car, perhaps in all our R230's, there is no computer code for "Convertible top pump is not responding/dead" so instead the display picks a random code for the trunk or top. This guy replaced the pump and for a week I have not had any problems whatsoever.
Old Jun 6, 2021 | 08:13 PM
sjmohr's Avatar
2014 SL 550 Sport Package
I had the exact same situation. Trunk pulled down tight after repairing leak, but open trunk warning still appeared. What worked for me was (1) opened trunk (2) pulled PSE Pump fuse (3) Closed trunk (4) Unlocked trunk manually with blade key (5) replaced PSE Pump fuse (6) closed trunk.
I have no idea what items in the sequence are necessary. All I know is that I started with just pulling the fuse out and putting it back in and that did not work. Listed above is what I happened to do next and it worked, so - with a try.
Old Jun 7, 2021 | 02:08 AM
BenzNinja's Avatar
Former Vendor
you don't have to guess neither take it to a mecanic if you get a proper diagnostics with Wis and Epc
https://mbworld.org/forums/e-class-w...benzninja.html
Old Jun 7, 2021 | 12:17 PM
Gene Fiorot's Avatar
SL500
When I read your post I was hoping someone would answer where is the switch that controls the "trunk is open". Unfortunately, most responses seem to be soft close option. My -04 Sl500 does not have this and I get the message on occasion. I usually have to close the trunk with a little more force to eliminate the message. So the question remains for me where is the switch. Gene
Old Jun 7, 2021 | 01:34 PM
sivikvtec's Avatar
2005 SL65 AMG
All SL models in the US have a soft close trunk, and the switch that detects if the trunk is closed is built into the self-close trunk actuator.
Old Jun 7, 2021 | 01:37 PM
SL500
LOL I never tried it! Ok so I am in the same boat Thank you Gene
Old Jun 8, 2021 | 02:32 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
The failure rate on the soft close is very close to 100%, so while it has the feature, it is very likely that it doesn't work. With the trunk open, turn the latch 1 click closed. At that point, soft close should take over and close the latch completely. If not, your soft close isn't working. After you test, pull the handle to release the latch so it will close normally.
Old Dec 13, 2021 | 05:00 AM
Klimfilt's Avatar
Mercedes W164 350 2006, Gas 4matic 272 hp/ Mercedes W201 190D/ Mercedes W213 E220D 4matic
Hello, can some one tell me the part number of this electrical motor ? I had the same problem on my 220d 2019s Benz. And a scheme of the location on it?
Old Dec 13, 2021 | 05:46 AM
ph1958's Avatar
2005 SL500
I had the same experience in my 2005 SL500. I eventually went to the MB dealer to replace the locking mechanism (as it had an air leak, I believe). After 17 years, the mechanism needed a replacement.
Old Dec 13, 2021 | 09:30 AM
slkfla's Avatar
2007 sl550
The soft close on my 2007 SL550 worked since I purchased it 2 years ago but I had to push the trunk almost to the fully closed position get it to take over. During a cold snap (65 deg in FL) I started to get the same red warning and was getting ready to do the excellent repair from this forum. I was always suspicious of having to push so far down for the pulldown and even manually closing the trunk by hand did not turn out the light so before I tore into the trunk lining I turned the 2 large plastic stop bolts in 1/2 turn each. Reset the pull down by removing and reinstalling the fuse. Trunk now works great! It's been over 2 weeks and still going great.
I may still have to do a complete repair in the future but this simple fix is worth a try for anyone having pulldown issues.
Old Dec 13, 2021 | 01:31 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Sounds to me like a normal and decent adjustment of your trunk lid. If the trunk lock soft closes, and it keeps doing that for a while, you're set.
I guess the soft close was intended to work with an auto closing trunk lid, really. For the poor lot like myself who have to pull the lid down by hand there isn't much of an advantage, compared to a decent mechanical lock. Although slamming the lid may crack the 3rd stop light. Oh well.
