SL/R230: Vibration at higher speeds
1) flat spot on tires..that is when car is sitting too long at the same place.
2) out of round wheel - unlikely if you never had issue w/ vibration before on the same set of wheels and tires .. but you never know..if you hit something hard it may have damage (the other side of the wheel which you can't see unless you jack the car way up high and look from the inside) OR if you just had your tires remount/replaced and the mechanic screwed up and 'bent' the wheel a little (tires still go on OK but wheel has a bent spot). This happened to me on my other car and I tell you, no amount of balancing could rectify the vibration you feel at high speed - in my case 60+ miles/hour .. so I gave that car to my son : problem solved :-)
I bought a set of 'flat stoppers,' which are molded foam plastic forms on which you park. I use them anytime that I know that I will not be driving, like Winter storage. They are pricey, but absolutely cure the flat-spot problem.
Tyre flat spotting is also very real , that would tend to be speed related and not in waves. However I did see a recommendation for simply increasing the tyre pressure ( 45 psi ?? ) just as a test to see if this helped as a diagnostic step.
