SL/R230: Hot Wire V1/Radar Detector
Old Aug 24, 2003 | 12:25 AM
LAMAY123's Avatar
A 2-Seater Roaster & A 4-Door AMG & 2008 S550
The dealer told me they might have to drill a hole on the dash when hotwiring the detector
Has anybody here hotwired their car??? Where can I get it done w/out drilling a hole???
Old Aug 24, 2003 | 07:53 AM
blueSL's Avatar
SL55 AMG
Depends on where you want to mount it...
I've mounted a Road Angel GPS Camera Detector on the windshield of my car and rather than have the wire snake across the dash to the cigar lighter, I run the cable along the front edge of the dash and down through one of the screw covers; you have to drill a hole underneath the screw cover but once you've done that, it's easy to connect up. If I sell the car, I can just replace the screw cover and no-one will know it ever existed...
Attached Thumbnails Hot Wire V1/Radar Detector-cable-run.jpg
Old Aug 24, 2003 | 07:56 AM
blueSL's Avatar
SL55 AMG
I used a spare position in the fuse box to connect up, the 3A lilac coloured fuse connects the Road Angel to the switched 12v line.
Attached Thumbnails Hot Wire V1/Radar Detector-fuse-box.jpg
Old Aug 24, 2003 | 02:25 PM
LAMAY123's Avatar
Thanks for the picture.
I want to mount the detector on the windshield, just above the clock. However, the technician (from MB dealer) has never done one on SL yet, and he wants to "research" and drill a hole by the clock and connect it from there instead of from the cigarette lighter.
Old Aug 24, 2003 | 02:36 PM
blueSL's Avatar
SL55 AMG
As you can see, I've mounted mine in front of the steering wheel, the cable runs to the nearest screw cover; if you want to mount above the clock, you'll definitely need to drill a hole somewhere, not a job for the faint-hearted - that's why I went in through the screw cover.
Attached Thumbnails Hot Wire V1/Radar Detector-road-angel.jpg
Old Aug 24, 2003 | 02:38 PM
blueSL's Avatar
SL55 AMG
Of course, the steering wheel is on the wrong side for you guys, but the principle is the same, the fuse box you need to go into is in front of the driver. To drill the hole, I used a Dremel with a right angle drive attachment and lots of light to see what I was doing.
Old Aug 29, 2003 | 04:28 AM
W210's Avatar
2000 W210 E55->2003 R230 SL500->2004 W211 E55->2007 997TT+2007 E63->2010 GLK350->2012 E550 4matic
Lightbulb Hot Wire V1
I mounted it on the sun visor for best reception. No holes drilled on dash or anywhere.
https://mbworld.org/forums/showthrea...threadid=11841
Old Aug 29, 2003 | 04:39 AM
blueSL's Avatar
SL55 AMG
So how does power get to the visor and how do you route the cable down into the ashtray area?
Old Aug 30, 2003 | 12:58 AM
W210's Avatar
It was done by a professional installer. He did have to take the centre console apart and removed the plastic ashtray to route the cable there.
The installation took him 2-3 hours.
I cannot remember whether he ran a power cable from the overhead console area to the visor area or if he ran the cable up the A pillar.
The power cable looks just like a regular phone cord with a RJ45 plug and was tugged behind the visor when not used.
