SL/R230: R230 SRS Fault - B1859
SRS light on, Per my Autel AL619 code reader;
9077 error code
VINs in control module N2/7 (Restraint systems control unit and N73 ( EIS [EzS] control unit) are not identical.
Looks like someone must have changed out the N2/7 module in the past. Does anyone know if this has to go to dealer to be replaced with a new unit and programmed with correct VIN or can the existing unit be reprogrammed?
Any help would be appreciated. Thanks
N73 control unit must be original because I recently purchased a new key from dealership and it matched the VIN of the car.
You can purchase an SDS from alibaba.com or eBay for as little as $300. I have read that most of these systems have the developer key installed. I have read on this or another forum that there are free applications on the internet that will generate a developer key for systems which do not have one installed.
