SL/R230: Brake fault code C261D
For put its 20" niche wheels On, suddenly the brakes stop working, the fault code is C261D, someone can give a hand? What this code means??
Thanks and sorry my english writing
If youve seen this code and say just leaks , does that mean a replacement master cylinder cured the problem , is it a common issue you see regularily ??
Cheers
Cheers
no problem
I gave a response as the original post, short
I would expect a more expanded initial post
What is the cause that you touched this
What have you done, not sure about "the operator tried several ways to do this" as there is only one way explained in WIS
That you can apply that pressure doesn't mean it holds pressure
The last statement is what i was after , the code points to the master cylinder- we read on the machine that the Travel of the pedal was out of Value , the operator explained that the Master cylinder could be the issue , he had never seen this code or had this problem in over 20 years at MB , my question is to the Forum " is this a common issue " , the hope being that the prolonged period of being laid up prior to my ownership might explain this , have you seen or dealt with this before , does a replacement Master cylinder BOU cure this ?
Thanks for the reply .
with these details, yes, you can go for a master cylinder replacement
rare issue indeed
buy a used one from ebay of course
good luck
