SL/R230: 2003 SL500 Driver Side Super Low after Service
Any ideas???
I had the car on 4 jack stands level (all 4 wheels off the ground) but only the driver side wheels off. Before final assembly (wheel wells and wheels and back on the ground) I did start car twice to check for any oil leaks. Started it twice. Not sure if this caused a problem?
The original issue was turning car off and it dropped/sagged within a day. Also, any small bump or speed bump I would get the short ABC Warning (classic Large Accumulator failure). FYI both large accumulators had failed.
Since the hyd lines are so short and the hose ends are bent it seemed pretty obvious where the lines went. I will double check all the lines and let the forum know. Thanks!
FYI when I turn car off it quickly adjusts to close to level?
Any ideas would help?
Also, I may try to manually bleed system (bleed ports at all four wheels). Do I bleed with car running? Do I bleed with car on ground or with all four wheels off the ground?
Look at the actual values with SDS and see why they are out. try manual actucations, and see if one goes the wrong way, will tell you if you have a valve or hose swapped.
Thanks.
Do I not have to have the Mercedes tool to do a rodeo? I have for two days now manually cycled the raise lower button a lot and now change. I will try to bleed system. just not sure proper procedure? car off ground? car running? does it matter which corner to start with? ect.
moretech
Also, this morning I removed all 4 wheels and used a jack on the bottom of the A-arms and compressed them as I opened the bleed valve at each corner. Wheels back on and obviously sitting very low. Started car and same issues. Driver side shoots up (like air in system) and passenger side drops, once up the raise and lower button is very smooth and normal. On the low setting I get the red to low alarm and it goes away at middle and high settings. It does seem like the front is raising and lowering more than the rear? again when I shut it off the car levels itself and I can see the rear dropping now.
I will post any solutions if I have any....
moretech
A trip to my 'Indie' and application of his 'Star' device resulted in a magical 'settling' of the car into a proper stance.
Suggest you try that route before anything more radical.
All the best.
